Effects of running super rich?
Old Aug 9, 2004 | 09:37 AM
ki3t's Avatar
This user can set his title.
Default Effects of running super rich?
I wanted to know what are the con's of running super rich besides bad gas mileage.
I recently went for an emissions test and holy cow is all I can say. Legal limit I guess you can say for "Gas injection" is like 1.8 or something like that in PA.
Guess what, my test showed as 8.3. Not the exact #'s but I have to go home again and re-check it.
Is it that bad to run rich like that? I am running with a chipped ECU.
Old Aug 9, 2004 | 09:40 AM
RTW DC2R's Avatar
could ruin the cat, and your plugs wont wear like they should. plus you probably arent making the power you should be making. atleast you know you arent pinging lol
Old Aug 9, 2004 | 09:44 AM
ki3t's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote"> plus you probably arent making the power you should be making. atleast you know you arent pinging lol</TD></TR></TABLE>
Dammit, I knew my power was fuxored. Stupid chips
Old Aug 9, 2004 | 10:00 AM
FourDoorTypeR's Avatar
You can also damage the inside of the cylinder walls when running real rich. I would get some type of engine management to lean that out some. What are you mods?
Old Aug 9, 2004 | 10:02 AM
ki3t's Avatar
Default Re: (FourDoorTypeR)
Absouletely stock JDM motor. Basic I/E/H & chipped p28
Old Aug 9, 2004 | 10:04 AM
Default Re: (ki3t)
Do you currently have a CEL? (Check Engine Light)
ki3t's Avatar
Nope... runs perfect.
Old Aug 9, 2004 | 10:07 AM
Hmm, not sure why the ECU is running so much fuel. Have you checked the condition of your spark plugs?
Old Aug 9, 2004 | 10:47 AM
RTW DC2R's Avatar
Default Re: (iijrzpnoyii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iijrzpnoyii &raquo;</TD></TR><TR><TD CLASS="quote">take out your cat and you can shoot flames out of your exhaust. </TD></TR></TABLE>
then you can stand behind it and hopefully catch on fire damn racist
Old Aug 9, 2004 | 10:51 AM
ki3t's Avatar
then you can stand behind it and hopefully catch on fire damn racist </TD></TR></TABLE>
I think he's following me around cause he was stupid and lost his avatar and had
racist
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">damn racist </TD></TR></TABLE>
I missed something didn't I
Old Aug 9, 2004 | 10:53 AM
esponet's Avatar
running toorich,and you could was down the cyl. walls. causing exessive wear on your rings and walls. contaminating the oil could also lead to pre-mature bearing failure.
if you wouldlike to keep the ecu, go get a vafc to lean it out. and fix the fuel curve. but i recomend you do this on a dyno or atleast have acess to a wide band o2.
too lean could be bad news too
Old Aug 9, 2004 | 11:33 AM
Justin Klemgold's Avatar
Is this by chance an EBAY chip?
Old Aug 9, 2004 | 11:43 AM
ki3t's Avatar
Default Re: (Justin Klemgold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">Is this by chance an EBAY chip?</TD></TR></TABLE>
n0o0o0o....it's a pretty well known person.
Old Aug 9, 2004 | 11:57 AM
JinDIESEL's Avatar
Default Re: (ki3t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki3t &raquo;</TD></TR><TR><TD CLASS="quote">
n0o0o0o....it's a pretty well known person. </TD></TR></TABLE>
his name wouldnt be "ebay" would it? hehe jkz. this is why im gonna run stock ecu
DB1_559
Mar 31, 2007 04:40 PM
Hyaboosta
Sep 7, 2005 03:32 PM
ALMXDUPINTEGRA
May 7, 2005 06:44 AM
ludelvr
Sep 28, 2002 09:43 PM
hybrider
Jul 27, 2002 11:23 AM
