high CR engine break-in
Old Aug 9, 2004 | 03:38 AM
JBBNJ609's Avatar
Default high CR engine break-in
ok so i have a b18c1 with a cr of close to 12:1 (jdm p30 civic si pistons)
no cams in it yet(just stock ones) ( will get them after i break in the engine)
i have uberdata and im lookin at a plx m300 WB
i have 440cc sat injectors
im afraid to start the car un tuned and mess up my motor by running too lean or too rich. the first 20 30 mins of a rebuild motor are the most important and if i have problems with rich/lean the rings or pistons may get fucked or the like
what should i do ??
i live in NJ and i see some fo you are in NJ as well
if someone will tune/ help me tune my car in the area i'll def pay
Old Aug 9, 2004 | 09:25 AM
99B16Si's Avatar
start tuning it instantly. since u have the wideband in there it should not be too difficult to get a nice stoich idle out of it. if u dont want to do that and are tryin to start building a map from scrach just try a stock ecu at first and adjust the fuel pressure accordingly to get a decent mixture and make sure the timing is where it needs to be
Old Dec 13, 2004 | 11:16 AM
Ress887's Avatar
Default Re: high CR engine break-in (jason bouchard)
12.1:1? with just p30's?
Im doing the same setup and have found b18c1's with p30's to yield 11.6ish:1 using c/r calculators.
Not doubting you, just wondering how you came up with 12.1.
With PCTs in s C1 completely stock i have found it to be in the 12:1's.
I am also wondering what i should do about break in process for my motor.
Brandi18c1
Engine Management and Tuning
10
Dec 15, 2012 07:14 AM
B16CRXT
Nov 18, 2007 03:18 PM
civicjdmb16a
Nov 25, 2005 08:02 AM
StreetracerVL
Dec 26, 2004 04:36 AM
ek9lau
Aug 9, 2003 02:33 PM
