!!!!! SHIT !!!!! Leaking mount hole in block! Help!
Old Aug 8, 2004 | 09:05 PM
Benny Z's Avatar
Default !!!!! **** !!!!! Leaking mount hole in block! Help!
Today I pulled my engine to begin building the block for turbo. The plan is to ship it off to have it sleeved (GE), and then load it up with forged pistons/rods.
However, I just went out to the garage to take another look at my baby, and just about **** my pants when I saw this...
What the heck?
There appears to be oil leaking from the AC bracket/torque mount where it mounts to the block. Looks to be about a 2" diameter dark stain around the bolt hole with a glistening substance shining on the ridge of the hole.
Is my block fuct?
Old Aug 8, 2004 | 09:40 PM
N2O's Avatar
N2O
Default Re: !!!!! **** !!!!! Leaking mount hole in block! Help! (Benny Z)
It could be some oil that leaked out of the ac comp. What you could do is find a bolt that is the right length apply a nice amount of silicone and tighten it down.
It is cheaper than buying a new block.
Old Aug 8, 2004 | 10:13 PM
mmuller's Avatar
Mad Scientist
clean it up and look at it again, i dont think thats anything
Old Aug 9, 2004 | 05:13 AM
Benny Z's Avatar
Default Re: !!!!! **** !!!!! Leaking mount hole in block! Help! (N2O)
*bump
i will clean it really well with a q-tip tonight after work and see what happens.
i have not had an ac compressor on the car since i put this engine in. ...and i cleaned the block thoroughly before putting it in the car. this has accumulated over the last 12-14 months.
Old Aug 9, 2004 | 09:47 AM
99B16Si's Avatar
sealant and a bolt should do the trick if there is a pinhole in there somewhere...just make sure theres no cracks
Old Aug 9, 2004 | 09:57 AM
im_poor's Avatar
Default Re: (99B16Si)
if there is a crack it will just get worse with vibrations.
Old Aug 9, 2004 | 12:28 PM
Benny Z's Avatar
Default Re: (im_poor)
I shined a light down the bolt hole when I went home for lunch, and the end of the hole appears to be intact and no cracks. All the threads also look good. There is, however, a tiny bit (we're talking maybe a tear drop) of standing fluid at the back of the hole, and most of the hole appears to be somewhat wet.
I should also note that this hole did *not* have a bolt in it for the last year. I had 3 of the 4 bolts holding the bracket to the block (yes, I know I should've fixed that sooner).
I'm hoping it's just crud that got in between the block and bracket since there was no bolt there, and just random fluid in the hole.
I will know for sure after I clean it out tonight.
There is no oil galley behind the mount holes, is there?
Old Aug 9, 2004 | 01:50 PM
KS-R's Avatar
Default Re: (Benny Z)
That hole should be the coolant water jackets behind there... But I could be wrong.
Old Aug 9, 2004 | 02:43 PM
vtec69's Avatar
Default Re: (KS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KS-R &raquo;</TD></TR><TR><TD CLASS="quote">That hole should be the coolant water jackets behind there... But I could be wrong.</TD></TR></TABLE>
Id also agree with this
but they sell this thing at a lot of auto stores that you pour into your oil and shine a black light and it will turn diffenert colors
not sure exactly how it works but its worth a shot
-Brian
Old Aug 9, 2004 | 05:09 PM
tvrsir's Avatar
Default Re: (vtec69)
find the hole and jb weld the bitch
Old Aug 9, 2004 | 06:43 PM
Fkned's Avatar
Default Re: (tvrsir)
if it only leaked that much in 14 mns then i wouldn't worry that much.But like said above just put some silicone on a bolt and screw it in,that sould fix the leak.
Old Aug 9, 2004 | 06:47 PM
sporkcrx's Avatar
Default Re: (fkned)
I REALLY doubt that's coming out of that hole there. I'd look elsewhere.
DCTegg
Aug 23, 2009 12:00 PM
biggoofy
Feb 13, 2009 06:28 PM
sohczchf
Welding / Fabrication
Nov 16, 2004 12:08 PM
gsrcivic619
Apr 8, 2004 05:30 AM
PSU-TEG
Apr 30, 2003 08:55 AM
