REBUILD PROBLEM
Old Aug 8, 2004 | 06:21 PM
slammedcoupe's Avatar
Default REBUILD PROBLEM
Engine was taken out of the car(D16Y8) and air conditioning was removed. Bottom end stock crank, eagle rods, SRP pistons ARP head studs. As for the head just a Comp Cam and re-adjusted the valves, and the rest, Skunk 2 Intake manifold, 520cc MSD injectors with stock fuel rail+regulator. Skunk 2 exhaust cat-back AEM CAI, New wires and plugs 2 degrees colder. Anyways the engine was rebuilt and put back in the car. All connections were hooked back up except for 1 air conditioner plug.
ANYWAYS HERE IS THE PROBLEM, When the engine is started up it is not burning all the fuel, you can smell it out of the exhaust and the cat goes RED HOT!! and it just seems like its not running right. Also the check engine light stays on.
NEED HELP ASAP!!!!
Also am going OBDI chipped with hondata and going turbo.
Old Aug 8, 2004 | 06:39 PM
89s1's Avatar
Default Re: REBUILD PROBLEM (slammedcoupe)
what code is it throwing?
when was the last time the injectors were balanced?
whats the fuel pressure?
those 520's are probably making it run pig-rich.
any SAFC or VAFC's or anything?
I would throw the stock injectors back in till the turbo is on.
Old Aug 8, 2004 | 06:40 PM
PodRacerSi's Avatar
Possibly a bad O2 sensor, Maybe a clogged or melted cat also.
Old Aug 9, 2004 | 12:17 AM
anothersickhatch's Avatar
Default Re: REBUILD PROBLEM (PodRacerSi)
haha holy ****. 550's? those are WAY TOO BIG for that motor. you dont even need gsr injectors for that motor. get them out of that damn motor ASAP
you arent running a DSM motor with a huge *** turbo.
Old Aug 9, 2004 | 07:01 AM
senpai's Avatar
What do you have controlling the 520's?
slammedcoupe
Aug 13, 2004 02:38 PM
slammedcoupe
Aug 12, 2004 09:01 PM
slammedcoupe
Aug 8, 2004 06:57 PM
slammedcoupe
Aug 8, 2004 06:34 PM
