15/16 or 13/16 for rear disc
Old Aug 8, 2004 | 05:48 PM
4DRmafia's Avatar
Default 15/16 or 13/16 for rear disc
which 1 should i run with my rear disc without the 40/40 proportion valve?
Old Aug 8, 2004 | 05:54 PM
4DRmafia's Avatar
oh pls no 1 knows i need this answer before tmw morning
Old Aug 8, 2004 | 06:08 PM
4DRmafia's Avatar
Old Aug 8, 2004 | 06:22 PM
Rostr02's Avatar
Default Re: (SkipMic2006)
i just did my swap with my stock hf prop valve
pedal feel sucks
Old Aug 8, 2004 | 06:31 PM
crexer's Avatar
Default Re: (Rostr02)
Why would you not just get the prop valve and do it the right way? 90-93 DA master cylinder and brake booster. NON ABS
88-91 prelude MC
90-91 EX MC
88 accord lxi MC
all bolt on but the 90-93 MC and BB is the straightest swap with no bending of lines.
Old Aug 8, 2004 | 06:44 PM
4DRmafia's Avatar
so which 1 do u think i should go with ?
Old Aug 8, 2004 | 06:48 PM
crexer's Avatar
90-93 integra MC and bb non abs
Old Aug 8, 2004 | 06:50 PM
4DRmafia's Avatar
i was just talkin abt a master clyinder
Old Aug 8, 2004 | 06:59 PM
AZTEKEF9's Avatar
i tought that the 90-91 ex is a traight bolt in...
Old Aug 8, 2004 | 07:03 PM
4DRmafia's Avatar
it is and i was wondering can i use that instead of changing the bb and the porportion valve too
Old Aug 8, 2004 | 07:08 PM
crexer's Avatar
if u just wanna do the job halfway then the 90-91 ex non abs is the one that bolts onto your stock brake booster. what year is your car? i dunno if this will make an improvement because you will be pumping more fluid thru your stock prop. valve. I would wait and do everything at once
Old Aug 8, 2004 | 07:14 PM
4DRmafia's Avatar
it is a 1990 honda dx hatchback and the 13/16 did felt good but what does 15/16 feels like
Old Aug 8, 2004 | 07:25 PM
Targa250R's Avatar
be professional
Default Re: 15/16 or 13/16 for rear disc (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">which 1 should i run with my rear disc without the 40/40 proportion valve?</TD></TR></TABLE>
Um, neither, because you shouldn't be running your rear discs without the proper 4-wheel disc proportioning valve.
Unless you just like swapping discs for the hell of it and having them not do anything, therefore taking away from your car's braking abilities . . .
13/16" master cylinders are way too small and can't move enough fluid for upgraded brakes. Your pedal will feel like **** without a larger master cylinder.
Old Aug 8, 2004 | 07:33 PM
4DRmafia's Avatar
how much will the vavle cost me ?
Old Aug 8, 2004 | 07:35 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">how much will the vavle cost me ?</TD></TR></TABLE>
I don't know. Find yourself a '90-93 non-ABS Integra in a junkyard and take it.
Old Aug 8, 2004 | 07:39 PM
4DRmafia's Avatar
so can i use a 15/16 with a 40/40 valve?
Old Aug 8, 2004 | 07:46 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">so can i use a 15/16 with a 40/40 valve?</TD></TR></TABLE>
Yes.
sicc83's Avatar
Default Re: (Targa250R)
You will be okay using the stock prop valve with the 15/16" master. Getting the correct prop valve may make a small difference, but it's not a saftey issue running the stock one. I didn't bother swapping my prop valve and my setup works just fine. I installed the mc, booster, rear discs, ss lines, pads and rotors all at once and it stops much better than stock. It's good enough for me.
If you're worried about the stock prop valve causing a problem, don't worry. See how it feels, and if you think you need to swap it, go ahead.
Old Aug 8, 2004 | 09:13 PM
Rostr02's Avatar
Default Re: (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">Why would you not just get the prop valve and do it the right way? 90-93 DA master cylinder and brake booster. NON ABS
88-91 prelude MC
90-91 EX MC
88 accord lxi MC
I did not have it at the time I did my swap today thats why. I do plan on replacing it
Old Aug 8, 2004 | 09:15 PM
Rostr02's Avatar
Default Re: 15/16 or 13/16 for rear disc (Targa250R)
"Unless you just like swapping discs for the hell of it and having them not do anything, therefore taking away from your car's braking abilities . . ."
Shut up kent ur just mad cause I got an hf
Old Aug 8, 2004 | 11:47 PM
T12UNK5's Avatar
use a 15/16 mastercylinder.. its off a 90-93 integra.
Old Aug 8, 2004 | 11:56 PM
4DRmafia's Avatar
well i am not really worried abt the valve and i just wanted to know if i can use a 15/16 from a ex sedan and call it a day?
Old Aug 9, 2004 | 07:14 PM
4DRmafia's Avatar
well guys i tested out a 13/16 with crx rear disc and it felt fine
Old Aug 11, 2004 | 11:47 AM
Mattamotor's Avatar
Because you havent felt it with a 15/16ths MC and right valve yet . My cars pedal feels like a rock and stops very quickly.
If done correctally you should begin to lock up the rear brakes alittle before the front, and if you really step on it you should be able to lock all 4 wheels. which then means you need better tires which is a whole nother topic.
Old Aug 11, 2004 | 12:00 PM
4drEF's Avatar
Keyboard Humorist
Get the correct prop valve from a CRX with rear discs.
That car came with the 9.5" front discs and rear disc so it will be identical to the setup you have.
I believe they had a 7/8" master cylinder.
Ideally that is what you would want, but 13/16" should be OK, but probably a little squishy.
You need a little more fluid to work those rear calipers than you do for actuating drums.
15/16" would be a better choice than 13/16".
Skip the Integra MC and booster.
Waste of time IMO.
Just get the MC from a 90/91 EX sedan.
It's the same size as the Integra one and it bolts right on to your booster.
No hassle of having to swap out boosters.
You CAN use the non-abs OR the ABS Integra unit. It won't matter.
You can NOT use an ABS MC with a non ABS booster and vice-versa.
sinyce
Aug 2, 2016 10:48 AM
sedrohatchstyle
16
Aug 21, 2011 06:00 PM
oroca
Mar 20, 2009 07:25 PM
malubawla
20
Apr 9, 2007 04:28 PM
datnigabluberry
Sep 18, 2005 10:02 AM
