H22eg "shakes"
Old Aug 8, 2004 | 04:23 PM
spooned out's Avatar
Default H22eg "shakes"
okay car drives fine until now, i noticed the steering wheel and dash shakes at certain rpm mostly in 2nd and 3rd gear.. i eliminated somethings allready
new shocks.
new tires/balanced 205/50/16
HCP mounts
DSS axles
Its strange just to have it shake at higher rpms but limited to 2nd 3rd and sometimes 1st gear. When it passes a certain speed or rpm in that gear the shakings gone. Normal granny drives no problem only when i let the rpms climb. Any suggestions? the car has a very slight idle surge but i don't believe thats what causes the "shakes" i wonder if it would have anything to do with old worn bushings, like steering, control arms etc..
i allready tried the search but not one thats smilar to this.
any suggestions?
Old Aug 8, 2004 | 04:53 PM
Jason kiDD's Avatar
Default Re: H22eg "shakes" (spooned out)
Frank at DSS is still probably not giving people the right axle lengths..
Old Aug 8, 2004 | 04:54 PM
H23vtecEG's Avatar
make sure your mounts and exhaust are tight. tunning it a bit wouldnt hurt either at some rpms some engine need more fuel then others. mine shakes too but h-series in a civic aint exactly smooth riding like your parents camry.
Old Aug 8, 2004 | 05:01 PM
Jason kiDD's Avatar
Default Re: H22eg "shakes" (H23vtecEG)
hehe speak for yourself, my car idles smooth and drives smooth..
Old Aug 8, 2004 | 10:41 PM
jdmcivicferio's Avatar
Default Re: H22eg "shakes" (Jason kiDD)
mine idles like a kitten, but I bet your shafts are the wrong length
Old Aug 9, 2004 | 02:59 AM
poison's Avatar
Default Re: H22eg "shakes" (jdmcivicferio)
Mine idles like a kitten and screams like a virgin.
Describe more in depth of this shaking..
Old Aug 9, 2004 | 08:37 AM
simon98h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out &raquo;</TD></TR><TR><TD CLASS="quote">okay car drives fine until now, i noticed the steering wheel and dash shakes at certain rpm mostly in 2nd and 3rd gear.. i eliminated somethings allready
new shocks.
HCP mounts
DSS axles
any suggestions?</TD></TR></TABLE>
I'm having the exact same problem in my 98 Teg with H22A. Only when accelerating conservatively through 2nd and 3rd (99% of time), I get a slight vibration in the steering/dash. It's between say ~2000 to ~3000 rpm. As soon as I pass say ~3200 rpm, nothing ... smooth like silk. If I run through the gears quickly? No vibration/shaking. I'm really thinking it's the axles, I'm using 92-96 Lude mid-shaft, 86-89 Teg outers and shafts with 92+ lude inner joints. If it is axles, I'm guessing I need custom ones ....
I've been driving like this for over a month now, it's not getting any worse but it is annoying. BUMP! I wanna get to the bottom of this as well.
Si
Old Aug 9, 2004 | 08:44 AM
Turbogixxer's Avatar
Default Re: H22eg "shakes" (simon98h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simon98h22 &raquo;</TD></TR><TR><TD CLASS="quote">I'm really thinking it's the axles, I'm using 92-96 Lude mid-shaft, 86-89 Teg outers and shafts with 92+ lude inner joints. If it is axles, I'm guessing I need custom ones</TD></TR></TABLE>
You use the lude carrier and bearings? The integra ones are smaller.
Old Aug 9, 2004 | 09:22 AM
simon98h22's Avatar
Default Re: H22eg "shakes" (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
You use the lude carrier and bearings? The integra ones are smaller.</TD></TR></TABLE>
Sorry, don't really get what your trying to say ...
Old Aug 9, 2004 | 09:25 AM
The carrier (the three post thing) and the bearings and bigger on the prelude then on the integra, so you have too much clearance when you use the prelude CV cup on the integra axles and bearings.
Old Aug 9, 2004 | 09:57 AM
simon98h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">The carrier (the three post thing) and the bearings and bigger on the prelude then on the integra, so you have too much clearance when you use the prelude CV cup on the integra axles and bearings.</TD></TR></TABLE>
So this leads once again to custome axles .... booooooo
I guess it can't be a huge diff, I had these axles assembled at an actual CV shop and they never said nothing, weird. Any custom cv shops better than others for custom work ?
Old Aug 11, 2004 | 06:35 AM
fastwanabe's Avatar
its you axles.... I've benn through this many times.
Old Aug 11, 2004 | 09:53 AM
simon98h22's Avatar
Default Re: H22eg "shakes" (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">its you axles.... I've benn through this many times.</TD></TR></TABLE>
How did you overcome the problem ?
Si
Old Aug 11, 2004 | 05:09 PM
hondaZvic's Avatar
u guys ever think ur flywheel may have a loose bolt or 2?
mine was... after i tightened it, its considerably smoother.
91b18a1ls
Jul 10, 2011 10:54 PM
Samuels
Aug 15, 2009 05:57 PM
Samuels
Aug 12, 2009 06:05 PM
turbodust
Feb 28, 2009 10:18 AM
slowassR
Sep 24, 2002 12:48 PM
