Dual vtec solenoid
Old Aug 8, 2004 | 07:41 AM
weraider30's Avatar
Default Dual vtec solenoid
saw a duel vtec solenoid at a local shop on a d15b, anybody know anything about this...was new to me
Old Aug 8, 2004 | 09:25 AM
krazie1's Avatar
BANNED
Default Re: Dual vtec solenoid (weraider30)
WERD
Old Aug 8, 2004 | 10:59 AM
Sliced Beard's Avatar
Default Re: Dual vtec solenoid (krazie1)
it has double the VTEC y0!
bwwwaaaaaAAAAAAAA<FONT SIZE="3">AAAAAAAAAAA.....</FONT>
Old Aug 9, 2004 | 05:35 AM
sinister6's Avatar
dont laugh, there is ACTUALLY ONE engine have double VTEC
Old Aug 9, 2004 | 05:44 AM
sinister6's Avatar
Default Re: (sinister6)
OK, its sort of an experimental block actually, from my knowledge( read from somewhere ) only around 500 of them ever produced. the VTEC solenoid start giving + electricity at around 2300-3500 rom.., fully open at around 4500-5k rpm.. it also have an EGR valve..which is weird..some other stuff i did forgot..it should be a block that born in 1995
Old Aug 9, 2004 | 06:25 AM
2wickedtoyz's Avatar
ok i'm not a honda guy but to my knowledge vtec fills a valve with oil to modify the timing by letting the extra lobe get in contact with the valve. so having two solenoids would be useless unless there are two different timing adjustment besides the normal setting that would be activated. am i right?
Old Aug 9, 2004 | 08:51 AM
weraider30's Avatar
Default Re: (2wickedtoyz)
from my understanding like the single solenoid the dual opened both the exhaust and intake at the same time, but it can be adjusted to let the exaust or intake open later than the other for more power
Old Aug 9, 2004 | 02:44 PM
speedrealmcrx's Avatar
I came across this site which has an explanation of that motor. here is a link to it:
http://asia.vtec.net/article/d15b/index.html
Much easier than me going on about it.
Old Aug 9, 2004 | 06:22 PM
sinister6's Avatar
Default Re: Dual vtec solenoid (speedrealmcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedrealmcrx &raquo;</TD></TR><TR><TD CLASS="quote">I came across this site which has an explanation of that motor. here is a link to it:
Much easier than me going on about it. </TD></TR></TABLE>
link dead
Old Aug 9, 2004 | 06:46 PM
Fkned's Avatar
Default Re: Dual vtec solenoid (sinister6)
Isn't a D15b a 2 stage vtec motor?If so thats why.
Old Aug 9, 2004 | 08:40 PM
limey156's Avatar
Default Re: Dual vtec solenoid (fkned)
wouldnt it be cool if there was like fully variable vtec, instead of 2 seperatly sized lobes, one thats sloped, grows bigger gradually as needed, so the valves are always in the optimum operating range. it would add a whole new dimension to tuning i guess.....
Old Aug 11, 2004 | 10:19 AM
Rod.'s Avatar
Default Re: Dual vtec solenoid (limey156)
can some post a pic
Old Aug 11, 2004 | 10:52 AM
eastbay92cx's Avatar
Default Re: Dual vtec solenoid (redturbocivic)
I have one of these motors that I'm in the process of swapping right now =]. It's a 96+ japanese d15b. The one vtec solenoid controls the 'vtec-e', which switches the head from 12 to 16 valve operation via a rod in the rockerarms, and the second solenoid controls the vtec we all know about, the one which switches to a more agressive set of intake lobes. This is not done strictly for performance, but more for high gas mileage below ~3000 rpm, and the power (just like any other d16z6 or d15b) above the given rpm. I don't have a pic, but that link above worked for me..
Old Aug 11, 2004 | 03:52 PM
link worked fine when i clicked it
Old Aug 11, 2004 | 06:05 PM
weraider30's Avatar
can't see the dual solenoid
Old Aug 11, 2004 | 08:43 PM
sinister6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weraider30 &raquo;</TD></TR><TR><TD CLASS="quote">can't see the dual solenoid</TD></TR></TABLE>
the second solenoid just sit beside the first one. about 5 cm apart, i have seen it in a magazine, but i dont have a scanner
Stevemyster
May 16, 2011 12:45 PM
cloudconnected85
Oct 4, 2008 07:32 PM
Midori Green
May 7, 2008 07:10 PM
sileighty_911
Jun 3, 2007 08:10 AM
eumoria
45
Oct 13, 2004 11:47 AM
