How to adjust handbrake...
Old Aug 8, 2004 | 07:09 AM
delguiner's Avatar
Default How to adjust handbrake...
Hey Guys, my handbrake is just way too lose... this morning i woke up with the car in the middle of the street as it rolled down cause the handbrake wasnt tight enough. How do i tighten it? If someone can give me a little step by step id appreciate that! thanks boys
Old Aug 8, 2004 | 07:41 AM
GaRn's Avatar
why dont you also put your car in gear when you park? if you parking up hill, put it in 1st gear, downhill, reverse... use that AND your emergency brake..
Old Aug 8, 2004 | 01:41 PM
britishlude's Avatar
Default Re: How to adjust handbrake... (delguiner)
Look at this diagram it's no.9 to turn and adjust the play out of your handbrake
http://www.hondaautomotivepart...BRAKE
You will have to remove the centre console first to get at it, don't overtighten as you need a bit of slack so the brakes arn't binding at the rear, when the lever is down.
slammedCL
21
Feb 25, 2008 09:23 PM
ShinyNewPenny
Nov 9, 2007 11:35 PM
jsantosDC5
Aug 21, 2006 02:14 PM
AshleyC
Dec 7, 2004 01:08 PM
