T28 vs TD05H 14b, which is a better turbo?
Old Aug 7, 2004 | 10:00 PM
_Endless_'s Avatar
Default T28 vs TD05H 14b, which is a better turbo?
i know T28 is only slightly bigger than a T25 and slightly smaller than a T3. if i'm not mistaken, i think T28 is T3compressor and T25 turbine. i'm not familiar with Mitsubishi turbos so i like to know which is better among the 2 turbos and which one is bigger.
Old Aug 7, 2004 | 10:47 PM
TheShodan's Avatar
Moderator
Default Re: T28 vs TD05H 14b, which is a better turbo? (_Endless_)
The TD04 14b is actually slightly larger than the T25 and around the same size as the T28 in terms of compressor, trim, inducer and exducer sizes. on most hondas I'd say neither one is "better" than the other, w/ the exception of the GT25R and GT28Rs, which are different beasts all together.
Depending on what you're doing with this setup, I'd avoid both unless you MUST have the homemade project and feel like modding manifold adapters and such, with the exception of the HKS T2 flange manifold.
But hell, what do I know.. I've only had 3 turbo hondas
Old Aug 8, 2004 | 05:40 AM
_Endless_'s Avatar
Default Re: T28 vs TD05H 14b, which is a better turbo? (TheShodan)
if they're about the same size, which of the two flows better?
eljah0426
Mar 7, 2010 08:37 PM
Glove
Dec 10, 2009 07:24 AM
Fastjato33
Jul 13, 2009 11:46 PM
crj_lll
May 24, 2005 09:59 PM
hondaZvic
Jul 4, 2004 06:58 PM
