My Brake ducts (Pics)
Old Aug 7, 2004 | 03:15 PM
Dropspeed's Avatar
Default My Brake ducts (Pics)
I have had request for pictures of my Brake ducts so I will post them all here:
I puchased two NACA Ducts from Pegasus a few years back that where approx 6"x10" rectangles (I can't remember the actual size they started) I sat on my but in the driveway with a bench grinder and "trimmed" them into shape. Once they fit "good enough" I had them painted. I also had to remove the from bumper cover and remove the factory plastic grill with a dremel.
A few zip ties, 2 plastic license plate screws, some hardware store painted mesh, some plastic door edge guard, 2 silicone reduces and some metal reniforced ducting and this is what I came up with. This is a 5/5 project (5 feet at 5MPH they look good).
Note the plastic lic plate screw through the center to hold them in place:
It helps to have traction bars to zip tie the ducting to:
From about 5 feet away
I have experiment with a couple different ways to direct the air to the back of the rotors...............But at one point during an "off road excurtion" I ripped both ducts off of there mounts and ran them over. the result was I lost about 6" of duct so now they just "dump" the air about 2-3" from the back of the rotor.
Mattj
Old Aug 7, 2004 | 03:36 PM
gtierrr's Avatar
Default Re: My Brake ducts (Dropspeed)
looks pretty good!! but u mite wanna straighten out the right hand side ducting. considering theres nothing pulling the air through, it wont like the bends so much??
Old Aug 7, 2004 | 03:38 PM
BrokenLimits's Avatar
Default Re: My Brake ducts (gtierrr)
I was lookin at it going...where the hell is that other pic taken from and then I realized there was no motor in the car...
Old Aug 7, 2004 | 04:03 PM
Dropspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtierrr &raquo;</TD></TR><TR><TD CLASS="quote">looks pretty good!! but u mite wanna straighten out the right hand side ducting. considering theres nothing pulling the air through, it wont like the bends so much??</TD></TR></TABLE>
The bend are there to get around the radiator when it is installed..........................
Your right there is nothing pulling the air, but I bet the 100+ MPH wind pushing does OK
Mattj
Old Aug 7, 2004 | 04:06 PM
nfn15037's Avatar
How is that going to fit with a full sized radiator? The hose looks like it goes right over the lower radiator mounting tab.
Old Aug 7, 2004 | 04:17 PM
ebelp's Avatar
Default Re: My Brake ducts (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">How is that going to fit with a full sized radiator? The hose looks like it goes right over the lower radiator mounting tab.</TD></TR></TABLE>
Yeah, might have to use a Civic radiator.
Old Aug 7, 2004 | 04:18 PM
uNF$@#!'s Avatar
Holy batman thats some serious weight reduction. you replaced the b18c5 with a hidden hamster! your car must be running very fast now
Old Aug 7, 2004 | 04:58 PM
Nishant's Avatar
Default Re: My Brake ducts (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">Holy batman thats some serious weight reduction. you replaced the b18c5 with a hidden hamster! your car must be running very fast now </TD></TR></TABLE>
fast to nowhere
Old Aug 7, 2004 | 06:18 PM
nsxtasy's Avatar
H-T Order of Merit
Looks like you had your car's entire body chromed.
Old Aug 7, 2004 | 06:50 PM
len's Avatar
len
No flames in the brake duct.
Old Aug 7, 2004 | 07:12 PM
jonas's Avatar
cool import model in the 1st picture reflection
Old Aug 7, 2004 | 07:20 PM
Mugen Mike's Avatar
I imagine it will fit just fine, since the ducts were installed before he pulled the motor
Old Aug 7, 2004 | 08:05 PM
.RJ's Avatar
.RJ
Why the hell do you need brake cooling if you are driving flintstone style
Old Aug 7, 2004 | 08:09 PM
integrasi's Avatar
Default Re: My Brake ducts (.RJ)
isn't the hose on left of the car will touch crank pulley????
Old Aug 7, 2004 | 08:11 PM
paRRRker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Why the hell do you need brake cooling if you are driving flintstone style </TD></TR></TABLE>
haha...but on topic saweet ducts man
Old Aug 7, 2004 | 08:16 PM
ITR640's Avatar
flintstone power..........?
Old Aug 7, 2004 | 08:17 PM
paRRRker's Avatar
Default Re: (01ITR640)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01ITR640 &raquo;</TD></TR><TR><TD CLASS="quote">flintstone power..........?</TD></TR></TABLE>
he has no engine...so hes using his feet
Old Aug 7, 2004 | 11:02 PM
dandc2's Avatar
Default Re: (paRRRker)
those brake ducts are the hotness
Old Aug 8, 2004 | 12:12 AM
KOALA YUMMIES's Avatar
It looks like I'll be the first one to ask this but the brake ducts I'm assuming are for brake cooling, on say a roadcourse (the most likely place to experience brake fade) but does the traction bar work well on a roadcourse?
Old Aug 8, 2004 | 12:33 AM
88's Avatar
88
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">
nice legs... errr... i mean nice cooling ducts,yeah umm.
well then, theonly thing that i dont like about ur car is the mesh that u put inbetween the ducts, something looks weird about it . well if they work well w/e,
Old Aug 8, 2004 | 04:45 AM
Dropspeed's Avatar
Default Re: My Brake ducts (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
We there is no motor for a long period of time it leaves alot of time to clean the car,.......and I was shooting into the sun because I didn't feel like pushing the car around the other way.
Yes, The Ducts are for cooling the brakes on a road course and are very effective.
I have a couple thousand miles on the ITR from Gingerman. This is how I judged the performanceAll with Braided lines/no backing plates/ATE SuperBlue fluid
Porterfield R4S pads: After about the 3 20min session started to get some fade
Hawk Blues: Near the very last session of the day (5-6) started to get fade
Added brake ducts and could run a whole track day without brake fade.
Added NSX calipers and thicker rotors ran three full track days, 2 hard days at EXPO3 "The Beaver" and the following weekend at Gingerman .......................I didn't even bleed the brakes
I have recently (last year) switched to a Fastbrakes set-up with Willwood billet Superlites and 2 piece 11.75" Rotors, with the lack of a motor I have yet to test the set-up on the track.
I might be removing the front bumper cover and replacing it with stock if anyone wants to trade. Must be black and in no worse shape than mine
Mattj
Old Aug 9, 2004 | 06:50 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas &raquo;</TD></TR><TR><TD CLASS="quote">cool import model in the 1st picture reflection </TD></TR></TABLE>
hahahahhahahhahahahah, good eyes, LoL
hahahaha
Old Aug 9, 2004 | 07:13 AM
Ex-ITR5874's Avatar
Default Re: (Nvious R)
Looks better than mine...
I`m a poor ricer
Old Aug 9, 2004 | 07:19 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">I have had request for pictures of my Brake ducts so I will post them all here:</TD></TR></TABLE>
how did you(before ripping them and running them over) have them mounted to the brakes?
looks pretty good.. how much $$$ did the ducts themselves set you back?
Seatown
Oct 1, 2006 04:01 PM
dwarrick
May 19, 2006 10:45 AM
M15
15
Mar 13, 2006 08:23 PM
civicd15b2
Mar 29, 2005 02:40 PM
Diamond
Feb 27, 2003 07:46 AM
