99-00 SI harness question
It all depends on what car it is going into. If you are putting the GSR motor into a 99-2000 Civic DX/EX/LX/CX/Si, you should use the 99-00 Si harness, add the iab, change the IAT wiring, and then use an ecu adapter to run the 99 GSR ecu.
If the car is a 96-98 Civic DX/EX/LX/CX, use the 96-98 Civic EX harness, add the IAB, change the CKF, IAT, IACV, and distributor wiring, and you should be good to go.
I may have forgotten a few minor details, but you get the point. Do not try to use a 99-00 Si harness in a 96-98 Civic, or vice versa. The 99+ has one of the ecu plugs in the body harness, whereas the 96-98 have them all in the engine harness.
hmtcrxsir
Apr 27, 2019 08:09 AM
