gsr into em1/99-00 SI
Old Aug 7, 2004 | 11:26 AM
Seye's Avatar
Default gsr into em1/99-00 SI
i putting a jdm gsr swap and have a few questions for some ppl. that have done it before. i did lots of searches and got a lot of my questions answered, but i have a few more.
I know the integra harness is a 2 piece and the civic is a 1 piece, and i must use the civic harness for the swap. The question is, do i unplug all the sensors from the motor when i take the b16 out and leave the harness in the engine bay, then plug all the sensor up when i bolt in the gsr? Or is there a way to take the harness out of the car with the motor?
Also is there going to be any plugs that dont get used in the swap? i know there is a sensor on the IM of the SI that only the SI has, but is located somewher else on other motors. Also what plugs will need to be extended or changed?
I would realy like to hear from ppl. that has done this swap before. thanks in advanced.
OH, BTW, I will be running a obd1 p72 ecu
Old Aug 7, 2004 | 01:19 PM
99B16Si's Avatar
it is pretty much a plug and play deal but the civic harness wont have a couple plugs that you would use on the gsr intake manifold. its alot easier if u just get a skunk2 IM. as far as the harness goes i always leave it in the engine bay as there arent really any plugs that are hard to get to once the motor is in. if u want to take it out just pull out the batter and disconnect it from the fuse box and the ecu and itll come right out once unplugged
SanFranGunners
Apr 16, 2008 02:47 AM
CiviCVuE
Mar 9, 2007 02:47 PM
boomersz
Mar 4, 2007 01:11 AM
boomersz
17
Mar 3, 2007 07:25 PM
