Idle won´t stay still. Jumps up and dowm.
Old Aug 7, 2004 | 11:12 AM
jwaked's Avatar
Default Idle won´t stay still. Jumps up and dowm.
I have a B20Vtec with JUN III, 11.5 Comp, 310 Injectors and fuel pressure set at 62, and Ericks racing chip. The car runs great when you step on it, but runs a bit lean since after my 6th lap, the EGT goes to 13. The idle is driving me nuts, acts like I have a huge cam, idle jumps up and down all the time. Any ideas?
Thanks
Jay
P.D. Did a serach but found nothing that could help me.
Old Aug 7, 2004 | 01:12 PM
-faded-'s Avatar
Default Re: Idle won´t stay still. Jumps up and dowm. (jwaked)
is the car tuned to those mods? you do have a big cam, lol
Old Aug 7, 2004 | 03:48 PM
jwaked's Avatar
Default Re: Idle won´t stay still. Jumps up and dowm. (hybridlsR)
Erick Racing made a custom chip for it but as a mail order. The Jun III are not big enough to make the idle jump from 1000 RPMs to 2000 RPMs up and down all the time.
Old Aug 7, 2004 | 09:26 PM
Mike K's Avatar
lower your fuel pressure, adjust your idle screw and look for a vacuum leak.
Old Aug 8, 2004 | 11:52 AM
anothersickhatch's Avatar
Default Re: Idle won´t stay still. Jumps up and dowm. (Mike K)
sounds like a vacuum leak.
Old Aug 8, 2004 | 01:00 PM
ybgnidils's Avatar
Default Re: Idle won´t stay still. Jumps up and dowm. (anothersickhatch)
I concur.
Old Aug 8, 2004 | 02:36 PM
sk8phaze's Avatar
Default Re: Idle won´t stay still. Jumps up and dowm. (ybgnidils)
The JUN stage III cam is pretty big, but not enough to jump a big RPM range, my ls/vtec when it was first built started doing that and i have stock b16 cams, but as others said, check vaccum plugs, throttle cable, and fuel pressure
Old Aug 9, 2004 | 07:00 AM
jwaked's Avatar
Default Re: Idle won´t stay still. Jumps up and dowm. (sk8phaze)
I cannot lower my Fuel pressure because my EGT is in 13 which is pretty hot. The weird thing is that the fue pressure does not move, maybe 1 PSI when I disconnect the vacum hose. I´ll check for vacum leaks and throttle cable.
Jay
boostedb20ek
Dec 11, 2009 12:52 PM
turboB16RFD
Oct 9, 2005 09:15 PM
VTEC Visions
49
Sep 3, 2005 11:19 PM
mrx
Jun 25, 2005 08:01 AM
raene
Nov 8, 2002 06:38 PM
