Cams are at TDC and crank is at TDC, but when I hit it with the timing gun it shows the white line l
Old Aug 7, 2004 | 10:27 AM
Thrillhouse's Avatar
Default Cams are at TDC and crank is at TDC, but when I hit it with the timing gun it shows the white line l
I just put my engine back together, I put the timing belt on how the book says, the cams are at TDC facing "up" with the lines facing each other lining up on the head. The crank is at TDC with the white mark lining up. I turned it on and it ran fine, but when I hit it with the timing light, it is showing the white TDC mark lining up with the marker on the dust cover, not the red one. I have to push the dizzy all the way towards the firewall for it to be close to the red mark. I dont get it. How can it be off if everything lines up. Plz Plz help
Old Aug 7, 2004 | 11:57 AM
SkRiBLaH's Avatar
Default Re: Cams are at TDC and crank is at TDC, but when I hit it with the timing gun it shows the white li
the timing belt is off by a tooth
Old Aug 7, 2004 | 12:06 PM
LudeyKrus's Avatar
Yup; I believe it's usually the exhaust cam that's off a tooth when it throws the line off like that.
Old Aug 7, 2004 | 12:23 PM
OTT's Avatar
OTT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">I just put my engine back together, I put the timing belt on how the book says, the cams are at TDC facing "up" with the lines facing each other lining up on the head. The crank is at TDC with the white mark lining up. I turned it on and it ran fine, but when I hit it with the timing light, it is showing the white TDC mark lining up with the marker on the dust cover, not the red one. I have to push the dizzy all the way towards the firewall for it to be close to the red mark. I dont get it. How can it be off if everything lines up. Plz Plz help</TD></TR></TABLE>
The up marks are facing directly up yes?
The way you worded it saying the marks are 'facing each other' made me wonder
Old Aug 7, 2004 | 01:13 PM
Yeah, I got it right, for some reason it was off a tooth but it didnt look like it, stupid me, I am just super frusterated so its hard for me to concentrate. Thx for the help tho
mike:
Honda CR-V & Element
Jul 10, 2014 05:38 AM
shesinmyroom
11
Jun 7, 2012 08:07 PM
1sikhatch
Feb 23, 2007 08:17 PM
88rexdxa6ed
Apr 24, 2004 11:51 AM
Lei Siew Long
Mar 31, 2004 12:43 PM
