timing problem
i just finished installing my head and everything. Now, after installing my timing belt, the timing is off. I made sure the crank pully was at tdc and also made sure the cams where tdc. After everything was done, i took out the timing light and did the timing. From what i can see, i tried to adjust the distributor to the max and still am inches away from tdc when using the timing light gun. Its like a quarter inch away from the white line towards the firewall. Has this happened to anyone? when i put the gun to 0 degrees the pointer is on the red mark. how do i fix this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE »</TD></TR><TR><TD CLASS="quote">You jumped a tooth. Need to go back and realign the crank and cams to tdc.</TD></TR></TABLE>
x2
x2
nope check it like 3 times, number 1 piston up white mak on crank aligned with the pointer and the cam gears up marks in position and the lines aligned with the mark on the cover.
You probably didn't install the belt correctly. Did you install it over the exhaust cam first, BEFORE putting it over the intake cam? You must install it over the exhaust cam gear first to take the slack out of the long side of the belt. If you install it over the intake cam gear first, you're going to have extra slack on that long run and timing will be off, or you'll jump a tooth and timing will be even farther off.
line up the grooves and time it properly.
if it's up more then 10 degrees the pistons will hit the valves, then you need a head job
suprised the car is running if you don't know what your doing, don't touch it! good luck!
Cams are at TDC and crank is at TDC, but when I hit it with the timing gun it shows the white line l
Thrillhouse
Aug 7, 2004 01:13 PM
