is the crank pulley on zc a right hand thread or left hand thread
Old Aug 7, 2004 | 08:00 AM
ZCHF's Avatar
Default is the crank pulley on zc a right hand thread or left hand thread
i still acnt get the pulley off. I cant get a hold of some ait tools, so i need to buy a breaker bar and try ang get it right. So counterclockwise loosens this correct, just like normal bolts? It starting to **** me off
brian
Old Aug 7, 2004 | 08:03 AM
crown14's Avatar
Default Re: is the crank pulley on zc a right hand thread or left hand thread (ZCHF)
you are correct sir
Old Aug 7, 2004 | 08:15 AM
speedfanatic88's Avatar
if all else fails take your car to a tire shop,they always have air tools so they could probably zap it loose for you...
Old Aug 7, 2004 | 08:20 AM
ZCHF's Avatar
Default Re: is the crank pulley on zc a right hand thread or left hand thread (speedfanatic88)
yeah, but the car doesnt run, the timing belt broke, so i am goign to put a new one on, but you cant put on on until the cover comes off, and the pulley needs to come off so the cover can come offf. stupid honda..damn
Old Aug 7, 2004 | 10:49 AM
91civicEX's Avatar
get a big *** screw driver, take off your starter, jam it in the flywheel teeth, then get a big *** breaker bar, and break the bolt loose while the screwdriver holds the flywheel teeth.
Dutch_commando
11
Jun 24, 2017 08:26 AM
mrspeedy69
Jul 18, 2009 03:00 PM
SpOoLiNg CiViC
Jan 2, 2007 05:13 PM
crxcess
Feb 19, 2004 08:24 PM
xrocket21
Jun 4, 2003 04:35 PM
