retarding timing question
ok, just replaced my HG, and I need to retard my timing again, how much should I do it? my set up, d16z6, t25, 9psi, afc hack. I believe it was -9 b/f I took it off, but not sure..I didn't do it the first time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pa2play »</TD></TR><TR><TD CLASS="quote"> my set up, d16z6, t25, 9psi, afc hack </TD></TR></TABLE>
A man hows that setup of yours??? Good Power???
Just wondering how the turbo and Z6 get along??
is the BTM needed if you have a chipped ECU with retarded ignition/boost accounted for?
Is there something the MSD does that a re programmed chip (turboedit etc) does and vice versa?
Thanks guys
Thanks guys
rasinhell
May 23, 2005 09:12 PM
