retarding timing question
Old Aug 7, 2004 | 05:38 AM
pa2play's Avatar
Default retarding timing question
ok, just replaced my HG, and I need to retard my timing again, how much should I do it? my set up, d16z6, t25, 9psi, afc hack. I believe it was -9 b/f I took it off, but not sure..I didn't do it the first time.
Old Aug 7, 2004 | 06:58 AM
B18C1CYA's Avatar
Default Re: retarding timing question (pa2play)
just set it to stock and get a msd 6btm ignition, your looseing a ton of power with out it,
Old Aug 7, 2004 | 07:04 AM
-16V-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pa2play &raquo;</TD></TR><TR><TD CLASS="quote"> my set up, d16z6, t25, 9psi, afc hack </TD></TR></TABLE>
A man hows that setup of yours??? Good Power???
Just wondering how the turbo and Z6 get along??
Old Aug 7, 2004 | 07:29 AM
djnikko's Avatar
Default Re: retarding timing question (-16V-)
is the BTM needed if you have a chipped ECU with retarded ignition/boost accounted for?
Is there something the MSD does that a re programmed chip (turboedit etc) does and vice versa?
Thanks guys
Old Aug 7, 2004 | 07:34 AM
B18C1CYA's Avatar
Default Re: retarding timing question (djnikko)
if you have a prom that already dose it then no the btm is not needed
Old Aug 7, 2004 | 04:43 PM
pa2play's Avatar
Default Re: retarding timing question (B18C1CYA)
how much is one of these, "get a msd 6btm ignition" and right now I don't have the mondy garenteed, so what should I set the timing at?
Old Aug 10, 2004 | 05:18 AM
pa2play's Avatar
what i did is got my timing gun, set the dial at 10 and timed it to that, and it runs just like it did before.
jdmkid_82
Jan 16, 2009 11:36 AM
rasinhell
May 23, 2005 09:12 PM
99lspwr
Mar 4, 2004 10:37 AM
88ZCRX
Jul 20, 2003 07:19 AM
xtal
Oct 20, 2002 01:39 PM
