Y8 mani Mpfi swap question
Ok so i pretty much understand how to do this
im getting a complete y8 IM(injectors, fuel rail, TB), and plan on using PM6 ECU, si dizzy.
heres the link im following<U>http://www.hybridgarage.com/tech/4gtech/dx-zc-wiring.htm</U>
now if i plan on running the y8 injectors i wont need a resistor box so where do A3 and A7 go?
do i just leave them alone or cut them?
Modified by anti-ricecake at 12:55 AM 8/8/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic »</TD></TR><TR><TD CLASS="quote">you CAN NOT run the pm6 with y8 injectors
pm6 = peak an hold - obd0
y8 = saturated -obd2a(b)</TD></TR></TABLE>
Oh
caus there was soemone on this board with a z6 mpfi swap and he was running obd 1 injectors and a PM6 ECU...
Oh
Yes you can.
It's been many times.
What you can't do is use the injector resistor box with Y8 injectors.
The resistor box adds resistance making the impedance higher.
The Y8 injectors naturally have high impedance so you can't run the resistor box.
Yes you can.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">
Yes you can.
precisely
i plan on running no resistor box
but whatabout a3 and a7 from the ECU where do they go?
has anyone done the Y8 mpfi swap and can post
Yes you can.
precisely
A3 and A7 go just like the MPFI swap tells you.
A3 is for the #2 injector.
A7 is the #4 injector.
See the pinout on this site
http://www.fourthgenhatch.com/mpfi.html
jyacoba2009
21
Oct 7, 2009 05:29 PM
NHB
Apr 3, 2007 04:29 AM
