will 90-91 teg ls rear disc brakes fit an eg?
what trim civic do you have? if its non-rear disks, then you need the complete assembly (arms, rotors, hubs, brake lines, mbc, calipers etc.). it should fit. it will not fit 96+ civics. if you have a civic Si hatch, all you do is swap the rotors and calipers.
so it will fit and i dont need the trailing arms right and what is the mbc is that the master cylinder well see i haev 99si front brakes in my garage waitin for installation so im thinkin i should get the master cylinder also is that what you just told i think it is
what is etc see the car is at the junkyard and i need to know exactly what to get you know what i mean that means i can use the rear lca's also right
thanks for the help maks
lata
chris
[Modified by 01VaS2K, 2:52 PM 11/29/2001]
[Modified by 01VaS2K, 2:53 PM 11/29/2001]
[Modified by 01VaS2K, 5:37 PM 11/29/2001]
lata
chris
CheezeFrog
Feb 25, 2002 12:03 AM
