car won't start (already searched)
I'm getting fuel and no spark but the motor isnt even cranking all the gounds are connected and the starter is getting like 19 volts so i dont know whats up it dont even crank or anything the crank pully can be turned with a wrech im clueless
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3to4e »</TD></TR><TR><TD CLASS="quote">I'm getting fuel and no spark but the motor isnt even cranking all the gounds are connected and the starter is getting like 19 volts so i dont know whats up it dont even crank or anything the crank pully can be turned with a wrech im clueless
Problem with the starter circuit maybe? BYW 19 volts is way too high.
</TD></TR></TABLE>Problem with the starter circuit maybe? BYW 19 volts is way too high.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Problem with the starter circuit maybe? BYW 19 volts is way too high.</TD></TR></TABLE>
19 volts? you probably fried it.
I have the same problem and I just gave up. B16 crx was running before i parked it for 5 months, went tried to start it up all i can hear is the main relay clicking. All my fuses get power, ecu is not fried, starter gets power, added more grounds, and still wont start. In my case i think some wire snap inside the cover.
21 volts is way, way, way, way, way, way, way, way, way, way, way, way, way, way, way, way, to high. a battery should only be a 11-12 volts when car not on, and at 13-14 volts with car running. 21 volts could kill all your fuses and fry the wiring. Oh you might want to check all your fuses before you go replace the starter and or do a test on the starter it self. but if your battery is pulling that much voltage with the car off you got the wrong battery. Replace that asap.
i think my voltometer is trash i took the starter to auto zone and they said it was garbage so i dont know i ordered a new starter and had them check the battery and they said it was like 12.8 so we will see tomarrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3to4e »</TD></TR><TR><TD CLASS="quote">had them check the battery and they said it was like 12.8 </TD></TR></TABLE>
That sounds better.
That sounds better.
its kinda weird caz i dont know why th starter would go out like that caz i pulled it off my type r motor that worked fine and it sat for a day then i put it in and bam it dont work thats weird
i guess the starter was bad which i dont know how caz like i said when i pulled it off my type r motor it worked fine no problems ohh well it works now thanks for all the input guys
RockLee`
Sep 18, 2005 06:30 PM
Integra_Boi
Jul 31, 2003 08:13 PM
