Can you extract more HP out of stock cams with cam gears?
Old Nov 29, 2001 | 09:51 AM
JohnnyBoy's Avatar
Default Can you extract more HP out of stock cams with cam gears?
Anyone done it?
Old Nov 29, 2001 | 10:17 AM
B2FiNiTY's Avatar
Default Re: Can you extract more HP out of stock cams with cam gears? (JohnnyBoy)
There are a few people on this board that have cam gears with stock cams. The only person I can think of is VagoITR. Unless he got some aftermarket cams now.
Old Nov 29, 2001 | 10:29 AM
Big Phat R's Avatar
I did - it's good for a few whp (to find the sweet spot). Fuel economy will go down though.
Old Nov 29, 2001 | 01:27 PM
98R #448's Avatar
Default Re: Can you extract more HP out of stock cams with cam gears? (Big Phat R)
I got 5 hp to the ground. I had both set at zero. I got 170hp then advanced the intake +4 and the exhaust at zero and got 175hp to the ground. I say at least 4 or 5 to the ground with i/h/e
Old Nov 29, 2001 | 01:50 PM
B2FiNiTY's Avatar
This may sound stupid but can you cover the cam gears after tuning it? For example, while tuning the cam gears use a valve cover that has already been cut. Then after everthing is done, install a valve cover that has not been cut. Sounds reasonable right?
Old Nov 29, 2001 | 01:52 PM
B18CXr's Avatar
2-4ish peak hp
Old Nov 29, 2001 | 01:55 PM
kitkatR's Avatar
Default Re: Can you extract more HP out of stock cams with cam gears? (B2FiNiTY)
Yes that is what vagoitr did
Old Nov 29, 2001 | 02:53 PM
Dropspeed's Avatar
Default Re: Can you extract more HP out of stock cams with cam gears? (kitkatR)
On both my ls/vtec with stock ITR cams and on my current ITR as well as the 3 other b18s I had before all with stock cams, the intake cam like to be advanced 2-3 degree while the exhaust usually like to stay near zero. All where tuned on the dyno. I have two valve covers also, one to tune with (cut) and the stock one.
Mattj
[Modified by Dropspeed, 3:54 PM 11/29/2001]
sgnlab
Aug 31, 2010 05:11 PM
starcraftbw
Aug 18, 2007 08:05 PM
jrs2ksi
11
Nov 12, 2006 01:58 PM
Try2Live4God
Jan 17, 2004 11:15 AM
