HKS 40mm WG wonders
Old Aug 6, 2004 | 02:17 PM
Anthonyl469's Avatar
Default HKS 40mm WG wonders
OK...I have a revhard equal length with a 40mm HKS flange on it...I really don't want to have it rewelded...can I use this wastegate with a white spring and a boost controller to run around 8 psi?
Old Aug 6, 2004 | 04:48 PM
Default Re: HKS 40mm WG wonders (Anthonyl469)
anyone?
Old Aug 6, 2004 | 04:54 PM
Jared's Avatar
the bigger a gate is, the more it can bypass, so technically a bigger gate will allow you to run less boost.
Old Aug 6, 2004 | 05:00 PM
Default Re: HKS 40mm WG wonders (Jared)
so this will work good?
Old Aug 6, 2004 | 05:31 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anthonyl469 &raquo;</TD></TR><TR><TD CLASS="quote">so this will work good?</TD></TR></TABLE>
i dont see why it wouldnt..as long as you have the right spring..since the white is around 6psi you should be fine..do you already have the spring? if you gonna buy it you might as well just get the orange (7.5psi) and not run a boost controller at all
davidluko
Apr 10, 2007 01:17 AM
PINKS
Jan 22, 2007 01:12 PM
gsrt
Oct 16, 2006 11:24 PM
92 CIVIC HATCH VX
Feb 17, 2006 02:57 PM
vtec.dc2
Dec 28, 2002 08:03 AM
