B18A1 Crank in a B16A?
Old Aug 6, 2004 | 10:41 AM
Merilious's Avatar
Default B18A1 Crank in a B16A?
I have a B18A1 block at home and was planning on doing a LS/Vtec conversion. But what I was wondering was, is will the B18A1 crank fit in the B16A block?
And if it does, what are some problems if any that I would run into?
Old Aug 6, 2004 | 11:01 AM
JDMotive's Avatar
Default Re: B18A1 Crank in a B16A? (Merilious)
The b18a/b crank fits in the b16a blocks with no modifications.Uses the same mani bearings.You will need custom pistons though.You can either use stock b16a size rods and pistons with a 24mm compression height for a 1.50 rod taio,or LS length rods with a rebushed small end,and custom pistons(forgot who makes those) and end up with a 1.54 rod ratio.
James
executedace
Jun 5, 2010 11:27 PM
flavio
Aug 16, 2009 10:31 AM
89hatchboosting
Jul 2, 2005 07:19 AM
hondaboyB18C1
Jul 8, 2004 06:32 PM
lazyvietboi
May 20, 2003 02:01 PM
