Factory fog lights
I've got a '93 integra and the factory fog lights are both blown out...and I want to change the headlight assembly myself to projection lights....how does the headlight assembly come apart? and can the factory fog light bulbs be changed and what is the trick behind getting the bulbs out. and yes the fuse is fine...checked that already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeRNSX »</TD></TR><TR><TD CLASS="quote">You don't need to take out the headlights, there is a little 8mm screw on the foglight, just screw it out and pull the foglight out.</TD></TR></TABLE>
he's still going to need to take off his bumper if he wants to put projector lights on his car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeRNSX »</TD></TR><TR><TD CLASS="quote">for the projectors yes but first question he had was how to replace the light bulb.</TD></TR></TABLE>he wont need to know how to take off the "fog light" part because he's just goin to swap the whole light assembly out anyways, so he'll just undo the connections and leave the bulb in the fog light cuz it has to be blown if its not working. or if theres a fuse that goes to those fogs.. might wanna check that out.
also if you plan on doing H.I.D's on the projectors, i heard they look like ****.. that if you want a good beam of light, you'll have to modify your oem ones, to put a projector inside the lamp.. not sure if theres a way to modify the aftermarket projection's..
go get you some silver stars or PIAA's.. closest to H.I.D you're going to get w/o spending above 100.00 bucks
zachkiro
Honda Civic (2001 - 2005)
Oct 4, 2007 03:16 AM
