P28 question
Old Aug 6, 2004 | 06:14 AM
Redsun's Avatar
Default P28 question
I'm looking for a P28 to set up Hondata in my hybrid hatch. Because i live in UK, the P28's over here are found in Civic Esi (SOHC Vtec). D16 something, can't remember the engine code. Is this ECU the same as the USDM P28? Because i thought the P28's are found in Civic Si which is B16A?
Will hondata be compatable with this ECU?
Or should i just email the guys at Hondata?
Old Aug 6, 2004 | 06:43 AM
mmuller's Avatar
Mad Scientist
Default Re: P28 question (Redsun)
the ecu that came in the 99-00 civic si is the p2t, the p28 is just like yours and came in the obd1 sohc vtec civics
Old Aug 6, 2004 | 06:55 AM
Redsun's Avatar
So that means it's good to go with Hondata?
Old Aug 6, 2004 | 07:20 AM
wwood's Avatar
The p28 for the d series is the right one because over here the si/ex were not b series. Hondata changes most of the ecu functions anyways so thats how you get away with running that ecu on the b series.
Old Aug 6, 2004 | 11:08 AM
eyeamvic's Avatar
Default Re: P28 question (wwood)
The p30 is the OBD1 ecu that came in the earlier b16a's like the del Sol VTEC. So you're good to go with the p28. Probably the most common ECU used.
Old Aug 6, 2004 | 02:35 PM
b18cls1's Avatar
Default Re: P28 question (eyeamvic)
if your going to run hondata than all you will need is a obd1 ecu
nonvtec vtec it doesent matter you can convert any of them to do what you need
i done a p05 in a prelude running the vtec iab ect for a customer
Old Aug 9, 2004 | 06:42 AM
Redsun's Avatar
Thanks for the good replies guys. Hondata has a P08J listed on their website for compatable ECU's. I have a P08 from my JDM D15B. If what your saying is true about using any OBDI then i could just use this and save money buying the P28??
Old Aug 9, 2004 | 09:53 PM
b18cls1's Avatar
Default Re: (Redsun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redsun &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the good replies guys. Hondata has a P08J listed on their website for compatable ECU's. I have a P08 from my JDM D15B. If what your saying is true about using any OBDI then i could just use this and save money buying the P28??</TD></TR></TABLE>
if its going to run a vtec motor then you have to convert the ecu to vtec but it is possible
Old Aug 10, 2004 | 12:52 AM
eastbay92cx's Avatar
Default Re: (b18cls1)
the p08 is a vtec ecu, you should be fine
Old Aug 10, 2004 | 06:27 AM
Redsun's Avatar
Default Re: (eastbay92cx)
Yep P08 is Vtec ecu. I 'Should' be fine?
Thanks guys, i'm gonna check by emailing them. To make sure.
Steeve_Civic
Jan 19, 2017 09:05 AM
DELshaneSOL
Engine Management and Tuning
35
Jan 17, 2012 05:21 PM
Milab21
Mar 26, 2008 05:05 PM
MackSpeed-616
Oct 18, 2001 05:31 PM
