Eagle Rods ruining my life! Help please.
Old Aug 6, 2004 | 12:12 AM
ZCboost's Avatar
Default Eagle Rods ruining my life! Help please.
I'm installing Eagle H beams into my ZC VTEC motor(D16Z6) and when we put the rods on the crank and tried to spin it over the rods are hitting the cylinder walls. A freind mentioned that we should have the rods grinded a bit to make them fit. I'm sure this will work, however I'm worried about the rods being out of balance after this. The H beams are thick *****, so i'm not worried about losing strength out of them since the highest boost I run is 8 psi at the track. Any thoughts on the grinding or anything else I can do?? Thanks.
Old Aug 6, 2004 | 12:57 AM
eddyboy's Avatar
Default Re: Eagle Rods ruining my life! Help please. (ZCboost)
To get eagle rods to fit in a D series, you need to notch the block
http://www.theoldone.com/artic...tips/
Modified by eddyboy at 2:23 AM 8/6/2004
Old Aug 6, 2004 | 03:35 AM
photec2's Avatar
Default Re: Eagle Rods ruining my life! Help please. (eddyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddyboy &raquo;</TD></TR><TR><TD CLASS="quote">To get eagle rods to fit in a D series, you need to notch the block</TD></TR></TABLE>
notch you block never grind down your rods. That will make them weak.
Old Aug 6, 2004 | 03:39 AM
EX-T's Avatar
I'd say that notching you block would be your best bet also.
EG-AEHatchlock
Oct 14, 2005 04:16 PM
JDMCRX
Jan 30, 2005 02:17 PM
Laney
Sep 15, 2004 04:42 PM
slammedcoupe
Jul 18, 2004 06:53 PM
93H22ACX
Apr 27, 2004 09:05 AM
