195/55 or 205/50 on stock rims?
Old Aug 5, 2004 | 11:35 PM
petrv's Avatar
Default 195/55 or 205/50 on stock rims?
My ITR has 205/50 tires on the R15 stock rims, but I see that standard should be 195/55. Which one is better for performance? I want to keep the stock wheels, so should I rather switch it with some 195/55?
Old Aug 5, 2004 | 11:43 PM
Bbasso's Avatar
Default Re: 195/55 or 205/50 on stock rims? (petrv)
What do you mainly use the car for ?
Old Aug 5, 2004 | 11:46 PM
petrv's Avatar
Default Re: 195/55 or 205/50 on stock rims? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">What do you mainly use the car for ?</TD></TR></TABLE>
Hard road use + some light track 30min sessions.
Old Aug 5, 2004 | 11:49 PM
Bbasso's Avatar
The best IMHO for stock wheels is the stock tire, RE010. if you don't or can't spend that kinda money then Azenis are a great second choice in most people's eyes, I tend to lean toward the MXs better rain and more street friendly.
good luck.
Try a search for tires, that might help you to decide.
Old Aug 5, 2004 | 11:58 PM
petrv's Avatar
I didn't mean the manufacturer, but the size of the tire - 195/55 (this is stock size) or 205/50 ? Both sizes on the stock wheels (15x6 I think).
Old Aug 6, 2004 | 12:05 AM
SLCTyper's Avatar
I've got a set of 205 50 15 Azenis on right now (which actually measure wider than 205). 205s will put more rubber on the road than 195s which is seldom a bad thing.
Old Aug 6, 2004 | 12:59 AM
KOALA YUMMIES's Avatar
Default Re: 195/55 or 205/50 on stock rims? (SLCTyper)
But the sidewall bulging because its much wider than the tire can be a bad thing. If you had 7" wheels then it would be a bit different.
Old Aug 6, 2004 | 01:01 AM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petrv &raquo;</TD></TR><TR><TD CLASS="quote">
Hard road use + some light track 30min sessions.</TD></TR></TABLE>
this is the vehicle you bought 2 days ago?
Old Aug 6, 2004 | 01:23 AM
petrv's Avatar
Default Re: 195/55 or 205/50 on stock rims? (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">
this is the vehicle you bought 2 days ago? </TD></TR></TABLE>
Yes. This is the expected use of my ITR. I used my Prelude the same way, so I think the use of ITR will be similar .
Old Aug 6, 2004 | 02:27 AM
DutchITR1689's Avatar
It really depends on the brand and type. Because some 205 tires are wider than other 205 tires and some have a stiff sidewall and some don't.
I'm using 195/50R15 S-03 and it is already a bit wider than the 195/55R15 RE-010, so 205/50R15 S-03 will be even wider (too wide for stock rims IMO).
Modified by DutchITR1689 at 12:38 PM 8/6/2004
Old Aug 6, 2004 | 03:55 AM
Sinbro2's Avatar
Default Re: 195/55 or 205/50 on stock rims? (DutchITR1689)
the 205/50 makes it looks mean and wide had azenis on car for a while and no complaints
Old Aug 6, 2004 | 06:28 AM
nsxtasy's Avatar
H-T Order of Merit
Have you ever tried doing a SEARCH? You could easily find discussions such as...
https://honda-tech.com/zerothread?id=805111
https://honda-tech.com/zerothread?id=448021
and a lot more about specific tires in those sizes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">The best IMHO for stock wheels is the stock tire, RE010.</TD></TR></TABLE>
I agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">if you don't or can't spend that kinda money then Azenis are a great second choice in most people's eyes, I tend to lean toward the MXs better rain and more street friendly.</TD></TR></TABLE>
The Azenis aren't THAT much cheaper, when you take into account their rapid tire wear (they last about 2/3 as long as the RE010).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petrv &raquo;</TD></TR><TR><TD CLASS="quote">I didn't mean the manufacturer, but the size of the tire - 195/55 (this is stock size) or 205/50 ?</TD></TR></TABLE>
The stock RE010 is 195/55-15. The Azenis and the MX don't come in 195/55-15, so Rob was referring to those as 205/50-15.
In other words - first decide what kind of tire you want to use, and THEN decide on a size. If the tire you want comes in 195/55-15, then get it; otherwise get the 205/50-15.
98LS4dr
Jul 31, 2004 12:22 AM
ITR Factor
Dec 18, 2003 09:55 AM
Pompiuses
May 23, 2003 07:21 AM
TypeR1558
Jan 1, 2003 01:19 PM
Euro98ITR
Jul 15, 2002 05:47 AM
