koni yellow torquing bolt situation
Old Aug 5, 2004 | 08:41 PM
Origin's Avatar
Default koni yellow torquing bolt situation
i have another question about the koni yellows. where you adjust the firmness setting of the konis there are two bolts that you torque down to 22 ft lbs. i tried torquing the first bolt to 22 ft lbs and probably only will torque down to 15 before the whole shaft begins to spin. is it that you are supposed to torque the top locking bolt down to 22 ft lbs because if thats the case the shaft is still spinning. is it a big deal that it is torqued down correctly? i can see a little under an inch of thread sticking out. im not too sure if that is too much or too little, i would suppose to little, but just checking.
Old Aug 7, 2004 | 09:13 PM
Origin's Avatar
Default Re: koni yellow torquing bolt situation (Origin)
Old Aug 8, 2004 | 10:17 AM
Origin's Avatar
Old Aug 8, 2004 | 05:45 PM
stumpyf4's Avatar
Ive found that you need a 7mm( if I remember correctly) wrench or socket to hold the shaft (hex on the shaft at the top closest to the adjuster) while you torque down the nut so you can't really use a torque wrench here. I go by gut feel but make sure you get it pretty close. Once you are happy with this nut torque go ahead and jam the second nut on.
Old Aug 8, 2004 | 09:35 PM
99hatch's Avatar
i used an air gun once i got it tight enough so that the shaft started to spin and its workin fine...dont go too crazy with it though
Old Aug 8, 2004 | 11:17 PM
Origin's Avatar
Default Re: koni yellow torquing bolt situation (stumpyf4)
do you guys also see about an inch of thread give or take?
Old Aug 9, 2004 | 05:05 PM
stumpyf4's Avatar
Yup about an inch. Don't use a impact on the Koni's, you could probably spin the adjuster with the shaft and seriously f*ck something up.
UltimX
Suspension & Brakes
13
Oct 14, 2005 10:50 PM
Origin
Aug 8, 2004 02:52 PM
descartesfool
May 14, 2004 04:12 PM
lshobo
Mar 9, 2003 07:19 PM
jonsteR
Aug 10, 2001 08:55 AM
