Good Custom Piping Catback
I have a zigen rear muffler only and looking to get custom piping. What kind of resonator should i get? what size of piping should i run? Should I get rid off the catalyic converter?(any side effects). Some info from you guys whos running custom catback would help
Thanks alot guys
.Thanks alot guys
I heard Dynomax makes good resonators. If you are N/A, 2.25 or 2.5 is good enough. If you have a turbo appl. I would go with 3" diameter. As far as getting rid of the cat, if you are N/A, it's not worth it, hardly any gains and terribly polluting the air, not to mention $3K fine if you live in CA. If you are turbo, there will be some gains.
the guy above is right..but then again...custom piping is not going to give u that much power...for one reason..if u are gettign crush bend...lol....u will still get gains...but..lol...but no gains significantly greater than stock....if u are gettign custom i hope ur getting mandrel bent piping....but that costs more than 30 bucks unlike what crush bend would cost...
My two cents,
Khoi
My two cents,
Khoi
BTW, my car is bone stock. The stock piping i believe is 2.25(correct me if im wrong), so getting rid of the stock pipe and changing it to custom 2.25 wouldnt make any diffrence am i right?
i have custom piping catback. Im not using a resonator at all, just cat, then full piping to the muffler. stock piping is 2.25" really? whoa, dammit, thats the size i got for my piping because everyone told me to get 2.25" and not 2.5" because thats too big. dammit.
Crush bending is a cheap way of manufacturing exhausts. This type of fabrication is when the exhaust piping is simply bent to shape, u can tell on stock exhausts by how the diameter is decreased at the bend. This decreased diameter restricts the exhaust flow. Mandrell bends, however, utilizes heat treatment to bend the piping and at the same time maintains the overall diamater of it. Therefore, you do not restrict exhaust flow throughout the system.
[QUOTE]i have custom piping catback. Im not using a resonator at all, just cat, then full piping to the muffler.QUOTE]
What kind of muffler do you have? hows the sound without resonator? hella loud huh?
ITRs are 2.25" but have 3 bad bottle necks. I doubt your piping is bigger than 2". Magnaflow has 2-1/4 systems for under $400 and they utilize mandrel bent tubing. Just to clarify, mandrel bending does not require heat to be applied to the tubing.
