why cant i idle??
Old Aug 5, 2004 | 07:56 PM
JlDlM Ek's Avatar
Default why cant i idle??
after i beat on my car a little.. my idle will jump from 1000 to 2000 rpm and keep going up and down for at least 5 mins... some say because of running too rich.. let me kno wut u guys think... thanks
wut i have in/on the motor
b20 block - eagle rods - wiseco 12:1 pistons
99 b16 head - skunk2 springs/retainers - skunk 2 stage 2 cams
str fuel rail - b&m f/p/reg - rc 310cc injectors
aem c/a/i - aebs typhoon intake man. - jdm type r headers
msd 6a ignition
Old Aug 5, 2004 | 09:13 PM
anothersickhatch's Avatar
Default Re: why cant i idle?? (JlDlM Ek)
sounds like that motor should get some hondata and tuning...it will run alot better.
for the idling problem, it could be alot of different things...
cap, rotor, spark plugs, spark plug wires, fuel filter, Idle Air Control valve, intake ait temperature sensor, fast idle sensor, and the list goes on. are you throwing any codes?
Old Aug 5, 2004 | 09:27 PM
IVI's Avatar
IVI
Default Re: why cant i idle?? (anothersickhatch)
probably a sensor making it do that
do you throw a cel when it behaves like that?
does it just stop on its own? or when you shut the car off and then start it again or let it cool off??
Old Aug 6, 2004 | 07:21 AM
JlDlM Ek's Avatar
Default Re: why cant i idle?? (IVI)
usually it stops on its own but yesterday i had to turn it off and turn it back on..
Old Aug 6, 2004 | 10:14 PM
IVI's Avatar
IVI
ya most likely a sensor.
clean out your throttle body.
Old Aug 6, 2004 | 10:31 PM
rtpassini's Avatar
im having the same problem....i have no clue whats going on with it yet.
Old Aug 9, 2004 | 07:14 AM
777Lude's Avatar
I am having that problem too. After a check, mine is running rich. It has to be something simple.
Old Aug 9, 2004 | 07:52 AM
village_idiot's Avatar
im having this problem too. its way not cool hope somebody figures it out.
Old Aug 9, 2004 | 10:52 AM
rtpassini's Avatar
the only code im throwing is the egr. and thats because i dont have it hooked up yet.
Old Aug 9, 2004 | 11:41 AM
1bad-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JlDlM Ek &raquo;</TD></TR><TR><TD CLASS="quote">after i beat on my car a little.. my idle will jump from 1000 to 2000 rpm and keep going up and down for at least 5 mins... some say because of running too rich.. let me kno wut u guys think... thanks
msd 6a ignition</TD></TR></TABLE>Have you checked for codes yet? If there is any?
Old Aug 10, 2004 | 07:44 AM
JlDlM Ek's Avatar
Default Re: why cant i idle?? (1bad-eg)
none.. but everytime it happens i can shut the car off and start it back up and it wont do it anymore..
Old Aug 12, 2004 | 06:23 AM
1bad-eg's Avatar
Check the fast idle valve. See if the inside portion popped out. That can cause the surge.
Old Aug 13, 2004 | 09:12 PM
777Lude's Avatar
Turns out my problem was the iacv was unplugged. idles fine now.
pornstartom
Dec 13, 2005 02:09 AM
Chillinit
11
Oct 24, 2005 12:04 PM
JlDlM Ek
Aug 11, 2004 06:02 AM
gobblebox59
13
Aug 2, 2004 01:51 PM
delSolLS
Jul 8, 2003 11:03 AM
