I need some help with checking rod bearing clearance how too's
Old Aug 5, 2004 | 07:08 PM
turbosi03's Avatar
Default I need some help with checking rod bearing clearance how too's
ok, if I mic the inside of the rods without bearings, mic the journals, and caliper the bearing thickness... that would tell me the clearance and I wouldn't have to connect the rod to the crank for plasti gauge... is this correct?
I was thinking of just doing plasti gauge, but put the piston rods, and rings into the block after installing the crank. THEN plasti gauge to check clearance. is that not a good idea?
which one would you do, mic or plasti gauge?
Thanks for any help!
this has been re-worded in efforts to make some sense...
Modified by turbosi03 at 11:33 AM 8/6/2004
Modified by turbosi03 at 11:35 AM 8/6/2004
Old Aug 6, 2004 | 05:15 AM
turbosi03's Avatar
Default Re: I need some help with checking rod bearing clearance how too's (turbosi03)
morning bump
Old Aug 6, 2004 | 05:20 AM
keithv's Avatar
You could build one of these to help you out.
http://m24x.zeroforum.com/zerothread?id=756
Old Aug 6, 2004 | 06:07 AM
turbosi03's Avatar
Default Re: I need some help with checking rod bearing clearance how too's (keithv)
yep... I made one of those but not quite as nice. 10 min deal here:
it does the job, but with the crank on the holder, I need to hold the rod in place. the only way I know how to do that is to use a bench vice but I can't with the pistons on the rods... I don't want to take them off so I'm wondering if there's a safe way to do it in the block?
or any other ideas?
from this point whats the easiest way?
Old Aug 6, 2004 | 10:35 AM
turbosi03's Avatar
bump for re-wording the questions up top...
feedback please!
2000dc2
Mar 17, 2009 07:31 PM
bluedlude
39
Jan 27, 2008 12:42 PM
Dublocivic
Dec 6, 2005 06:39 PM
Eric Schieb
Nov 30, 2001 07:04 PM
