93 Hatch B18C1 w/ turbo wont start
Old Aug 5, 2004 | 07:04 PM
13BT's Avatar
Default 93 Hatch B18C1 w/ turbo wont start
well guys a couple of weeks ago my friend purchased a 93 hatch with a stock GSR motor with a greddy bolt on turbo kit.
a couple of days ago he informed me that his car wouldnt start. i checked it out.
no blown fuses, checked the battery havent checked for spark yet.
what happens is that when you turn the key to the ignition position, nothing happens. no clicks, no starter grinding, no nothing.
called a friend he said the starter could be dead but if that were the case it would just grind right?
anyone have some insight on this?
Old Aug 5, 2004 | 07:19 PM
RoadRage04's Avatar
Default Re: 93 Hatch B18C1 w/ turbo wont start (13B)
let me guess, main relay?
Old Aug 5, 2004 | 07:29 PM
photec2's Avatar
Default Re: 93 Hatch B18C1 w/ turbo wont start (RoadRage04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoadRage04 &raquo;</TD></TR><TR><TD CLASS="quote">let me guess, main relay?</TD></TR></TABLE>
good job n00b if there is no "hiss" from your feul pump.. thats what i would check. $5 from local junkyrad. Also check your spark just incase
Old Aug 5, 2004 | 07:41 PM
DOHCtorTHRUST's Avatar
Default Re: 93 Hatch B18C1 w/ turbo wont start (photec2)
double check the starter, sometimes it wont even turn if its shot
Old Aug 5, 2004 | 08:03 PM
hatchi's Avatar
possibly main relay.
Old Aug 5, 2004 | 08:08 PM
mulin's Avatar
ha ha j/k
Old Aug 5, 2004 | 08:10 PM
13BT's Avatar
okay ill try to switch relays from my hatch. theyre all the same right?
oh btw, i forgot to mention the engine doesnt even crank.
Old Aug 5, 2004 | 08:14 PM
Hatchd's Avatar
Do any motor work to it? Did he decide that after buying the car he was gonna be Mr Fix it and go do something? I had this same problem in my hatch when we did the headgasket. Turns out one of the plugs.....yeah, it kinda didnt have the other half of the plug plugged into it. Check little things like that. You didnt do the work so you dont know what kinda job was done.
This is of course only if the main relay doesnt fix the problem.
ILUVTEC
Mar 20, 2010 01:31 PM
ILUVTEC
Mar 20, 2010 01:30 PM
91greenbeast
19
Sep 30, 2008 09:09 AM
DeadVet
Aug 10, 2005 07:50 PM
hawaiian_ej1
Jan 5, 2005 11:59 AM
