Short SHifters
Old Aug 5, 2004 | 01:31 PM
Russo757's Avatar
Default Short SHifters
Ok so I had a short shifter installed on my 99 teg the other day and I cant tell the difference. How noticable is the difference in distance? It really seems no shorter than the stock one. SOrry bout the noob ?
Old Aug 5, 2004 | 01:33 PM
90Integra's Avatar
Default Re: Short SHifters (Russo757)
Mine was a lot shorter.
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You had someone or someplace do it for you? Are you sure they installed the aftermarket piece? Did you buy it from them or did you buy it somewhere else and take it to them?
My shifter sits the same height as stock inside the car, but the throw is shorter than a stock 6-speed Miata shifter.
Old Aug 5, 2004 | 01:34 PM
Russo757's Avatar
Default Re: Short SHifters (90Integra)
some of the other threads that Ive read say that you should be able to shift with just your wrist... THe distance is still way too far for me to do that.
Old Aug 5, 2004 | 01:35 PM
Russo757's Avatar
Default Re: Short SHifters (PatrickGSR94)
I purchased it and had the same shop install it.
RidinStock's Avatar
Sounds like you don't have a short shifter.
Old Aug 5, 2004 | 01:42 PM
aznballer's Avatar
i have installed 3 short shifters. 2 in civics and one in an integra and u can feel the diff. its shorter distance to get it in gear and its stiffer
Old Aug 5, 2004 | 01:54 PM
MAV3RiCK478's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Russo757 &raquo;</TD></TR><TR><TD CLASS="quote">some of the other threads that Ive read say that you should be able to shift with just your wrist... THe distance is still way too far for me to do that. </TD></TR></TABLE>
depending on the car and the shifter but should be way shorter than the stock row boat throw.
Old Aug 5, 2004 | 01:55 PM
jdmhamster's Avatar
u should be able to tell a difference. which short shifter did u get?
Old Aug 5, 2004 | 02:25 PM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Russo757 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I had a short shifter installed on my 99 teg the other day and I cant tell the difference. </TD></TR></TABLE>
You sure they installed it in YOUR car? LOL
Old Aug 5, 2004 | 02:49 PM
smemts's Avatar
Default Re: Short SHifters (Marauder)
Yeah, you would most definately be able to tell the difference, in both the length of the throw, and the feel of it.
Old Aug 5, 2004 | 02:52 PM
SMC Integra's Avatar
remeber that most short shifters are actually short "throw" shifters. They reduce the amount of distance that the shifter has to travel between gears, a lot of times the remain the stock height.
Old Aug 5, 2004 | 03:11 PM
qcktegls's Avatar
Default Re: Short SHifters (SMC Integra)
i got a short shifter installed about a month ago and the distance is a lot shorter. it takes a quick flick of the wrist and it shifts. its tough to even tell if its in nuetral or in gear by lookin at it because its so short. good luck on the shifter man
Old Aug 5, 2004 | 05:00 PM
Russo757's Avatar
Default Re: Short SHifters (jdmhamster)
DC short shifter. The only thing that seems different is that I dont change gears as smooth any more. I think I got took..
Old Aug 5, 2004 | 05:06 PM
B2FiNiTY's Avatar
Depends what short shifter you get.
Old Aug 5, 2004 | 05:47 PM
civicbro's Avatar
Default Re: Short SHifters (B2FiNiTY)
You have to feel the difference. Maybe they didn't even install it?
Old Aug 5, 2004 | 06:24 PM
GS-Rdriven's Avatar
Default Re: Short SHifters (civicbro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMC Integra &raquo;</TD></TR><TR><TD CLASS="quote">remeber that most short shifters are actually short "throw" shifters. They reduce the amount of distance that the shifter has to travel between gears, a lot of times the remain the stock height.</TD></TR></TABLE>
i don't think any short shifters make the height of the stick shorter. I've called a couple companies and they all said that's something you have to do ur self or something else , i can't remeber.
lak8
Sep 12, 2006 06:55 PM
lacking vtec
Feb 11, 2006 07:36 AM
integra-modder
Jun 9, 2004 03:23 PM
tdog
Feb 11, 2002 06:35 PM
Lyonel
Jul 8, 2001 09:42 AM
