JRSC with alternator stepper pulley and jrsc crank pulley only 8psi!
Old Aug 5, 2004 | 12:29 PM
ATgrills.com's Avatar
Default JRSC with alternator stepper pulley and jrsc crank pulley only 8psi!
Well i finally got my boost gauge hooked up and I am pretty disapointed
I have a alternator stepper pulley and the JRSC crank pulley on my type R motor and I am only spiking to 7-8 PSI then falling down to about 5-6 PSI by 7K RPM...
Do you think the fact that I have a spearco water cooler have anything to do with my low boost problem!
I thought I would have like 10PSI with no spiking...
so how much PSI should I be running if I was not Intercooled!
Tyler
Old Aug 5, 2004 | 01:23 PM
RacerXI's Avatar
Default Re: JRSC with alternator stepper pulley and jrsc crank pulley only 8psi! (ATgrills.com)
Is that w/ a 4.2 nose pulley?
Old Aug 5, 2004 | 02:11 PM
Default Re: JRSC with alternator stepper pulley and jrsc crank pulley only 8psi! (RacerXI)
well its the stock one!
Old Aug 5, 2004 | 02:24 PM
Sonny's Avatar
Is your intercooler a water injection setup or something like the LHT where there is a "brick" inside the manifold? The LHT causes a couple psi of pressure drop. You shouldn't see any pressure drop with water injection.
Sonny
Old Aug 5, 2004 | 05:10 PM
Default Re: JRSC with alternator stepper pulley and jrsc crank pulley only 8psi! (Sonny)
Sorta like LHT but external intercooler.. seach my name for pics of my set up!!
so why the spike?????
Old Aug 6, 2004 | 06:25 AM
ttt
Old Aug 6, 2004 | 06:54 AM
Rory Breaker's Avatar
A stepper on your motor should only see around 9PSI...I would imagine if the air is passed through an IC, you should see some pressure drop.
The way boost drops at high RPM like that tells me the first thing for you to check would be alternator belt tension. Are you slipping at high rpm? What pulley is it?
Edit - I see you have the crank as well...together you should be seeing around 11PSI I would imagine.
Old Aug 6, 2004 | 07:10 AM
Default Re: JRSC with alternator stepper pulley and jrsc crank pulley only 8psi! (newgsrdriver)
but does a boost spike have to be either slipping or boost leak???
I want like 10PSI.. do you think a CRV crank pulley is bigger then the jackson one?
Tyler
Old Aug 7, 2004 | 09:10 AM
icivicracer's Avatar
i would say the belt is sliping......i had the same prob.. with the boost droping.. it was the alt belt
Old Aug 7, 2004 | 09:20 AM
Its not a spike, its a drop at high RPM, which indicates alternator belt tension problems, due to either tension on the belt, or a poorly designed stepper pulley which causes the belt to slip.
Old Aug 7, 2004 | 11:46 AM
there no way im changing the aternator pulley,, thats gonna be like a full day work!!
so i guess I should just try to tighten it...
so there no way its a leak?
Old Aug 7, 2004 | 12:14 PM
What alternator pulley are you running?
Old Aug 7, 2004 | 01:09 PM
i dont even know the guy gave it to me when I bought the charger..
its all black with no ingravings on it....
Tyler
Old Aug 8, 2004 | 01:08 PM
ttt
Old Aug 9, 2004 | 02:46 PM
today it was spiking till 7.5 PSI but its not enought!
Old Aug 14, 2004 | 10:10 PM
HYREV2NR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com &raquo;</TD></TR><TR><TD CLASS="quote">i dont even know the guy gave it to me when I bought the charger..
Tyler</TD></TR></TABLE> More than likely it's an ENDYN pulley. I change a SC & an ENDYN pulley on a Civic SI & it made about 10 psi.
Old Aug 17, 2004 | 05:30 AM
Default Re: JRSC with alternator stepper pulley and jrsc crank pulley only 8psi! (HYREV2NR)
ya but I have a intercooler so dont I lose like 3 PSI or something like that?
gosu08
Apr 27, 2009 07:49 AM
DjBurns
Apr 18, 2007 08:39 PM
mrx
Jul 12, 2006 06:30 AM
suprchrg95
May 17, 2004 01:10 PM
MADEINIRAQ
Nov 21, 2003 05:24 AM
