PLEASE HELP, EG6 problem...only one of my gauges works...ahhh!
Old Aug 5, 2004 | 10:43 AM
neocrynym's Avatar
Default PLEASE HELP, EG6 problem...only one of my gauges works...ahhh!
OK, I have a big problem I need solved ASAP. I already searched and didn't find much of use. I have a '92 CX w/ a '93 d16z6 motor in it. Just finished the swap a few days ago, and it runs beautifully. HOWEVER, when I plug in the Si's gauge cluster, ONLY THE TACH WORKS! WTF? None of these work: speedometer, odometer, gas gauge, and coolant temp. PLEASE HELP! obviously these are major issues any ideas what may be wrong? everything plugged right in to the stock CX harness, so I dunno what could be wrong. The cluster works, because it worked in the donor car before pulling the motor from it.
Old Aug 5, 2004 | 10:58 AM
EFing_bmxED's Avatar
Default Re: PLEASE HELP, EG6 problem...only one of my gauges works...ahhh! (neocrynym)
I just did the same swap into the same car and only my temp and fuel work in my stock cluster (my speedo doesent) so help me too please!
Old Aug 5, 2004 | 11:01 AM
neocrynym's Avatar
Default Re: PLEASE HELP, EG6 problem...only one of my gauges works...ahhh! (streetracer859)
did your speedo work before the swap?
Old Aug 5, 2004 | 11:05 AM
I8Stang's Avatar
check and make sure the plug ins between the cluster and the car's wires are plugged in.... i had the same problem.....
Old Aug 5, 2004 | 11:14 AM
yeah everything worked and everythings pugged in. the cable looks fine but do do speedometers break? i want to get an amber SiR cluster any way but im just curious
Old Aug 5, 2004 | 11:16 AM
neocrynym's Avatar
Default Re: (I8Stang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8Stang &raquo;</TD></TR><TR><TD CLASS="quote">check and make sure the plug ins between the cluster and the car's wires are plugged in.... i had the same problem.....</TD></TR></TABLE>
Well, all the harnesses taht fit into the cluster are plugged in. Do you mean check the connections between the end of that harness and the rest of the car's harness?
Old Aug 5, 2004 | 11:36 AM
I8Stang's Avatar
Default Re: (neocrynym)
yea.....
Old Aug 5, 2004 | 11:41 AM
neocrynym's Avatar
heh, good call....i haven't even thought of that yet, lol.
does anyone else find it ironic that the one thing the CX never came w/ (a TACH) works!? i do.....
Old Aug 8, 2004 | 05:57 PM
neocrynym's Avatar
well, I got all the gauges working except the gas gauge, and I have no idea what to do about that any ideas, anyone?
the speedo/odometer/temp gauges' wiring was just messed up a bit...
Old Aug 8, 2004 | 06:10 PM
CHiNkStEr's Avatar
try changing the green piece on the back of the cluster or something.
zerogravitycrx
15
Sep 12, 2005 02:48 PM
vmm
Apr 18, 2005 04:05 PM
Littlegreend15
Mar 19, 2005 02:41 PM
EgSick
Jun 25, 2004 07:07 PM
h82lose
Feb 3, 2003 04:46 PM
