b18a or b18b crx, have obd0 or obd1, what to do
i have a whole bunch of parts left over from buddies swaps and that, i have cable and hydro tranny, obd0-0bd1 dizzy's,injectors, ecu's ,everything needed for both possibilities of swaps, as said i have a 90 Crx si, was wondering are these engines good candidates for crx swaps, both tranny's are from LS, would i be happy with the performance from these setups, is it worth going up to the b18b, and then should i go obd1 or remain obd0, searched for results, or success, from this swap and nothing found,thanks for the help,
swap in the b18b and put on the obd0 distributor. The b18b has a better intake manifold, exhaust manifold, and cams that give it the extra 10 hp and 6 ft/lbs of TQ. Switch to OBD1 later after you get it running right.
the.hamburglar
Dec 30, 2005 08:10 PM
