What chip in P28 to use????
Old Aug 5, 2004 | 08:45 AM
EuRoBrO's Avatar
Default What chip in P28 to use????
I did my H22 swap and am running the sotck JDM P13, well my buddy let me try out his chipped P28 and it felt 1,000,000,000 times better than the P13. I am not exactly sure which chip he has in it but, the redline is like 8,500 or 9,000 RPM'S......thats waaay to high when I miss shift(which I did on accident) so I threw the stock P13 back in. What would be the best ECU with what chip and I got a VAFC and will go get tuned. My mods are all the bolt-on's no head work and no bottom end work. Thanks!
Old Aug 5, 2004 | 09:06 AM
Monkey Fing a Coconut's Avatar
Default Re: What chip in P28 to use???? (EuRoBrO)
im hoping the chip in the p28 was for an h22 when u ran it, otherwise, if ur going to run a vafc then there is no need to chip anything, best thing to do is though dtich the vafc and run hondata in the p28 and get it tuned
Old Aug 5, 2004 | 09:47 AM
PreludeRacer023's Avatar
Default Re: What chip in P28 to use???? (twistedbydezign)
you dont have to run an h22 chip in your P28...im usuing a mugen GSR chip in mine...my rev limit is at 9100, but even if your rev limit is set at 8k..and you misshift your motor will rrev higher than that, mine hit 9200 on my p13 with a mishift, checked it on my recall on my vafc when i had it, but i suppose if your prone to misshifting you shouldnt run it high anyways, that one time is the only time ive ever misshifted my car....and im sure people are gonna say that my using a GSR ecu is horrible for my car, runs lean...blah blah blah...my A/f. is very good throughout the rev range... between 13.2-13.7....all the way through on a wideband....there ya go
Old Aug 5, 2004 | 10:56 AM
EuRoBrO's Avatar
Default Re: What chip in P28 to use???? (PreludeRacer023)
Ok, thank you for the info......yeah I think the chip in my buddy's P28 is a mugen or Jun. Not to sure though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeRacer023 &raquo;</TD></TR><TR><TD CLASS="quote">you dont have to run an h22 chip in your P28...im usuing a mugen GSR chip in mine...my rev limit is at 9100, but even if your rev limit is set at 8k..and you misshift your motor will rrev higher than that, mine hit 9200 on my p13 with a mishift, checked it on my recall on my vafc when i had it, but i suppose if your prone to misshifting you shouldnt run it high anyways, that one time is the only time ive ever misshifted my car....and im sure people are gonna say that my using a GSR ecu is horrible for my car, runs lean...blah blah blah...my A/f. is very good throughout the rev range... between 13.2-13.7....all the way through on a wideband....there ya go</TD></TR></TABLE>
HondaGuy951
May 16, 2008 01:27 PM
ludedude1984
Apr 25, 2006 10:57 AM
alleyezonme
Aug 22, 2005 01:13 PM
EuRoBrO
Aug 5, 2004 03:27 PM
jdmcivicferio
Jul 10, 2003 04:07 PM
