1995 Accord crank bolt
Any advise on removing the crank bolt on my non- vtech engine? I've broken my ratchet extensions and my 3/4 to 1/2 adapter for impact- what next?
thanks alfred
thanks alfred
Search this board. You will find alot of discusison on this.
If not, i use a 1000 ft/lbs impact wrench with the proper socket and a very good air supply and just give it a go. THey are damn hard to get off...sometimes.
If not, get it down to a shop and have them break it off for you.
fs
fs
Honda say's they are torqued to 180 ft/lb's. My ***. Not even close. You must use eight a high powered impact with good air supply like 125psi. Or the special tool that fits inside the crank pully and a very long breaker bar. Trust us when we say its on there.
racekar
May 19, 2004 07:03 AM
