H22 bottom end
Old Aug 5, 2004 | 07:03 AM
CivicSiDriver02's Avatar
Default H22 bottom end
I am planning on running a H22 with some boost, but i need a crank that will be able to handle it. Do you guys know of any companies that make performance crankshafts for the H22? Thanks
Old Aug 5, 2004 | 07:15 AM
dasher's Avatar
Default Re: H22 bottom end (CivicSiDriver02)
OEm is good enough unless your planning on making over 1000whp...
... make sure you sleeve those h22's though
Old Aug 5, 2004 | 07:21 AM
dennis's Avatar
The crank is the least of your problems....
Old Aug 5, 2004 | 07:22 AM
Default Re: H22 bottom end (dasher)
Well, thats what i thought but i also blew up a basically stock h23. I was told by a mechanic that the crankshaft was cracked but i have yet to tear into it to find out. Have you ever heard of any thing like this of was he just giving me a load of you know what. Also, this my be a dumb question but if you sleeve your block does that also make it a closed deck block? Thanks again!!
Old Aug 5, 2004 | 07:28 AM
dennis's Avatar
you can get closed and open deck sleeves - just do a search on sleeves and you'll find more info than you can handle/want.
Like dasher said, honda oem cranks are pretty tough, but anything's possible I guess. I'd have a look at the crank though. If you spun a bearing, I'd probably look into a new crank depending on how bad it is.
dasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiDriver02 &raquo;</TD></TR><TR><TD CLASS="quote">Well, thats what i thought but i also blew up a basically stock h23. I was told by a mechanic that the crankshaft was cracked but i have yet to tear into it to find out. Have you ever heard of any thing like this of was he just giving me a load of you know what. Also, this my be a dumb question but if you sleeve your block does that also make it a closed deck block? Thanks again!!</TD></TR></TABLE>
h22's are closed deck to begin with, so sleeving it will keep it closed deck...
Your crank may be damaged but it wouldn't have been the crank which would have failed first but rather detonation throwing a rod into your crank which would have caused the damage .... OEM cranks are stout.
If your crank is damaged buy another used OEM one andhave it blueprinted -- don't waste 1000 dollars on an aftermarket one.
Old Aug 5, 2004 | 07:32 AM
dasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiDriver02 &raquo;</TD></TR><TR><TD CLASS="quote">Well, thats what i thought but i also blew up a basically stock h23. </TD></TR></TABLE>
first you mention an h22 , now your talking about an H23..... no matter - they are both closed deck to begin with.
Old Aug 5, 2004 | 07:39 AM
Well, I have a 94 Prelude Si which i blew up. So I am ordering a JDM H22 to replace the blown H23. I am planning on running boost to it and I was just worried that i would end up cracking another crank. I just figured that it was the weak point on the H series engines. If i dont need to worry about that crank then what would u think is the weakest point of the engine. Thanks again for your help!!
Old Aug 5, 2004 | 07:43 AM
dasher's Avatar
Here is the list-
pistons(ringlands)
sleeves (Thinner than B series)
Rods
Headstuds
You need to sleeve it to run most aftermarket forged pistons because H22's have frm sleeves.
Save up and do it all right from the get go ... don't cut corners.
Old Aug 5, 2004 | 08:05 AM
I know this is a stupid question but what are ringlands??? lol. Thanks again for putting up with my stupid questions.
Old Aug 8, 2004 | 06:27 PM
Evs-One's Avatar
Solbros Owns Me
h23 cranks are more prone to breaking than h22 cranks. h23 cranks done like to be revved very high.
fukenricen
Dec 25, 2009 03:37 AM
SiR-T
Apr 6, 2008 07:26 PM
ef9_frosty
14
Oct 2, 2007 09:00 AM
chandler
Apr 9, 2005 02:44 PM
