misfiring, how to fix it???
Old Aug 5, 2004 | 06:59 AM
Kyle244R948's Avatar
Default misfiring, how to fix it???
Cylinder 1 misfires does anybody know the causes from this and how to fix it. my injectors are sealed tight as are my ignition plugs. maybe a bad spark plug? or maybe the spark plug isn't tighten all the way. someone pleeeaaaseee help.
Old Aug 5, 2004 | 07:07 AM
RTW DC2R's Avatar
how many miles on the car? did you do the usual new plugs, cap/rotor, and maybe even the wires yet?
Old Aug 5, 2004 | 09:51 AM
Default Re: (RTW DC2)
45,000 everything is stock from when i bought it, jus new magnacore wires
Old Aug 5, 2004 | 09:53 AM
MattD@Stoptech's Avatar
Default Re: (Pwrd by HONDA R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pwrd by HONDA R &raquo;</TD></TR><TR><TD CLASS="quote">45,000 everything is stock from when i bought it, jus new magnacore wires</TD></TR></TABLE>
My guess would be on those...
either not on tight enough...slipped off....or just a crappy product...
Old Aug 5, 2004 | 12:12 PM
Filthy Focker!'s Avatar
Default Re: (El Pollo Diablo)
Swap the plugs and wires with another cylinder and see if the problem re-occurs!
fs
Old Aug 5, 2004 | 12:14 PM
Default Re: (filthy_shovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">Swap the plugs and wires with another cylinder and see if the problem re-occurs!
fs</TD></TR></TABLE>
how exactly would you plan on swapping wires?
Old Aug 5, 2004 | 12:17 PM
lanceh's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
how exactly would you plan on swapping wires?</TD></TR></TABLE>
enough with j00 nonsensical facts
Old Aug 5, 2004 | 12:44 PM
Chris N's Avatar
Default Re: (lanceh)
your bof asses.
Old Aug 5, 2004 | 12:56 PM
.RJ's Avatar
.RJ
Default Re: (Chris N)
shadetree, all tree of j00z
Old Aug 5, 2004 | 12:57 PM
lanceh's Avatar
25 Year Member
Default Re: (.RJ)
clah. i hate it when people delete posts as i'm writing a reply.
'invalid post' ownz me
Old Aug 5, 2004 | 01:00 PM
I deleted it because my answer was full of ****. I am not familiar with the ITR engine and when i saw the response i got, well, it did not make sense.
I did not realise that my answer was way off. You can't seem to be able to swap plug wires right?
fs
Old Aug 5, 2004 | 01:04 PM
94civicEX's Avatar
Check the plug on the cylinder that's misfiring, if that's not the problem put your stock wires back on. No reason to stray from stock wires anyways, stock Honda wires are the ****!
Old Aug 5, 2004 | 01:55 PM
lanceh's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">I did not realise that my answer was way off. You can't seem to be able to swap plug wires right?
correct. each plug wire is different length.
Old Aug 5, 2004 | 02:21 PM
98itR484's Avatar
ditch the magnacore wires, get some stock ones, Honda stock ignition is preforms really well.
And like mentioned, change the plugs/cap/rotor as well, and make sure the wires are tight
Old Aug 5, 2004 | 02:36 PM
Dr. EKology's Avatar
Default Re: (98itR484)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itR484 &raquo;</TD></TR><TR><TD CLASS="quote">Honda stock ignition is preforms really well. </TD></TR></TABLE>
I told you not to drop you ESL class last semester, Habib.
Old Aug 5, 2004 | 02:37 PM
98itR484's Avatar
Default Re: (EKology)
i tell you it be hard...you but say no
how that was bad...i guess thats what i get for sleeping soo much
Old Aug 5, 2004 | 02:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itR484 &raquo;</TD></TR><TR><TD CLASS="quote">i tell you it be hard...you but say no
how that was bad...i guess thats what i get for sleeping soo much</TD></TR></TABLE>
No seriously, you just hit rock bottom and started digging. Time to step away from the keyboard.
ty_uni_ek08
Oct 14, 2008 12:46 PM
Integrity_On_Wheels
Nov 20, 2005 10:06 PM
MackDad
Sep 10, 2004 06:59 PM
Rene M
May 9, 2004 05:29 PM
Mr. TopFuel
Sep 11, 2003 07:03 PM
