b18a/b question
I have searched but still have a few questions, I have a 01 integra ls, I am getting ready to buy a block and go from there. My question is is the b18a a pain in the *** to put into a 01 ls? I know the main diff. is sensor placement but is there any other diff that you know of(beside the head)? Can the b18a/b use the same pistons/rods and sleeves? Are the cranks the same? Will my ecu work with this block? Thanks!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls »</TD></TR><TR><TD CLASS="quote"> I have searched but still have a few questions, I have a 01 integra ls, I am getting ready to buy a block and go from there. My question is is the b18a a pain in the *** to put into a 01 ls? I know the main diff. is sensor placement but is there any other diff that you know of(beside the head)? Can the b18a/b use the same pistons/rods and sleeves? Are the cranks the same? Will my ecu work with this block? Thanks!!!</TD></TR></TABLE>
as far as the internals, sleeves, and ecu... yes they'll work. Its pretty much... plug and play as long as your state allows it for smog. it shouldnt be a pain in the *** any more so then replacing with an identical block.
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx »</TD></TR><TR><TD CLASS="quote">Why would you put a B18A in your car?
Plus If I remember you have to put the same year or newer engine only.
(state law)</TD></TR></TABLE>
well the b18a block is the same as a b18b block(except for some sensor placement) so why would you pay an extra 200-400 extra just so it would say b18b. It's getting built with a b18b1 head. As for as against the law I think I have better things to worry about than not having the same year or newer block in my car, I think not having a cat is more of a fine than the motor issue. Plus if you would read my question, did you answer it ? so why post!
