Greddy w/g question
Old Aug 4, 2004 | 10:54 PM
mrod006's Avatar
Default Greddy w/g question
is there any way to set the greddy 15g turbo to 0 boost cuz i am having probs with my car and i need to run w/o boost for a little while.
Old Aug 5, 2004 | 09:04 AM
TheShodan's Avatar
Moderator
Default Re: Greddy w/g question (mrod006)
No, the actuator rod doesn't work that way.
If you want to see 0 boost as you get your car repaired, simply disconnect one of the intercooler compressor pipes so it is not pressurized.
WARNING: This allows the turbo to spin freely very quickly, so don't drive like this for too long, (Like several weeks or a month) for you could damage the internal shaft bearings.
Old Aug 5, 2004 | 11:24 AM
Boost Addict's Avatar
Default Re: Greddy w/g question (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">No, the actuator rod doesn't work that way.
WARNING: This allows the turbo to spin freely very quickly, so don't drive like this for too long, (Like several weeks or a month) for you could damage the internal shaft bearings.</TD></TR></TABLE>
No, you can just disconnect the acuator rod. I know this works because I was driving once, and I wasn't boosting, and i popped the hood and saw the acuator rod had come off.
So just disconnect the acuator rod and you will not be boosting.
Old Aug 5, 2004 | 12:34 PM
Rtype16's Avatar
Default Re: Greddy w/g question (xPRELUDEx)
Yes if you dis-connect the actuator rod it will not be building any boost. It will just kick the flap open all the time. So you shouldn't be seeing any boost.
Old Aug 5, 2004 | 08:24 PM
mrod006's Avatar
Default Re: Greddy w/g question (Rtype16)
cool. i will prolly take it off anyways b/c i need to save for hondata and it's gonna take me some time. thanks for the replies. so if i disconnect the rod, there will be no shaft damage?
so if i drive with no i/c pipe for like a couple of days, it shouldn't harm the turbo much?
Modified by mrod006 at 12:39 AM 8/6/2004
Old Aug 6, 2004 | 03:34 PM
mrod006's Avatar
ok. i tried to take off one of the pipes and the car shut off. no vaccum so i have to disconnect the actuator rod. thanks for the help guys.
hitekper4mance
Jul 6, 2006 01:32 PM
Drkaccrd
Jun 3, 2005 06:18 PM
Pikachu
Jan 31, 2004 05:24 AM
GreddySi99
Jul 9, 2003 10:29 AM
nd8ch
Apr 11, 2003 12:03 AM
