i need help for my teg?
hey i have a 95 ls and for some strange reason my ABS light comes on after i pass and then slow down after 80 MPH. does any one know how to fix it>
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
What is the trouble code. There is a main code, followed by a subcode. Give me those numbers and I can give you an answer. 1st unplug the service check connector from the conector cover which is located on the passenger side of the center console. Then bridge two terminals of the service check connector with a jumper wire. Then turn the ignition to on but don't start it the ABS computer will then show you a beeping on on the indicator light. Main codes have a 1 second pause and sub codes have a 5 second pause. The ABS will only give you 3 codes at a time. So hopefully you won't have more than three things wrong with the system. Anyway hopefully this helps you, and if you need further assistance pm me and I can help you, or check your repair manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweezy225 »</TD></TR><TR><TD CLASS="quote">lol my abs just stays on as i drive... wut does that mean</TD></TR></TABLE>
did you replace any axle or suspension compnent and not get an abs part/
shortlid
Mar 15, 2006 05:04 PM
