ABS codes-94 Teg
Old May 27, 2014 | 07:28 PM
DaveDavidson's Avatar
Default ABS codes-94 Teg
Howdy. I just bought a '94 LS after my '95 GSR was stolen .
I'm happy with this car since I really missed my GSR. Anyhow, the ABS light is on and the ABS motor can be heard running from time to time. I did the fill/bleed of the ABS reservoir but the light still is on.
I got the code but I'm a little confused trying to interpret the result.
When I turn on the key the ABS light goes on then off for two seconds then on then off for five seconds then on then off for five seconds then on then off for five seconds. Each time its on for the code display its on for a second or two then off for 5 seconds.
There are no flashes followed by the next flash flash a second later except when you first turn the key on. That how you get 2 digit codes, right?
So it seems to by giving the "1" code which is the pump overrun code but its doing it 3 times. Does this sound right?
Old May 28, 2014 | 09:18 AM
tamboo's Avatar
10 Year Member
Default Re: ABS codes-94 Teg
here's the basics but reading the rest of section 19 wouldnt be a bad idea imho:
http://www.spooledupracing.com/downl...dfbd31fb819d41
Old May 28, 2014 | 05:23 PM
OK thanks. after reading your post I think I am getting the 1 code 3x over .
mr_munro
Mar 14, 2012 11:53 AM
Agent Daimon
Nov 8, 2010 12:03 PM
Havokgsr
Oct 1, 2002 03:25 PM
