emissions help, already failed once
Old Aug 4, 2004 | 10:32 AM
serious's Avatar
Default emissions help, already failed once
i'm trying to get my brother's car through emissions before he leaves for sub school at the end of august. it's already failed once with a hot cat and retarded timing. below is the diagnostic report they gave me. right now i'm thinking a basic tuneup and a new catalytic converter should do it. suggestions?
Old Aug 5, 2004 | 03:55 AM
serious's Avatar
Default Re: emissions help, already failed once (serious)
bump
Old Aug 5, 2004 | 04:01 AM
2lua's Avatar
look like you need a tune up and an oil change. you fail with hc being high.
Old Aug 5, 2004 | 04:25 AM
JinDIESEL's Avatar
Default Re: (2lua)
yup seems like it. oil change, tune up, and get 87 or the lowest gas you can. it will burn cleaner and better than normal
Old Aug 5, 2004 | 06:12 AM
allmotorcx's Avatar
Default Re: (JinDIESEL)
i pass my emission with using couple bottle of heet. always works. just make sure the tank are 1/4 empty. good luck
Old Aug 5, 2004 | 08:48 AM
blue2ksi's Avatar
your cat takes care of your hydrocarbons, that what u failed correct? i dont know if it is possible to fix a cat but replace it or something and i think you'll be fine
Old Aug 5, 2004 | 08:58 AM
dantastic's Avatar
i would try new air filter, cap, rotor, plugs, and a can of seafoam (de-carbonizing reduces NOX) before getting a new cat (~$100 from kragen/advanced)
Old Aug 5, 2004 | 09:22 AM
igo4bmx's Avatar
Are you serious??
what a bad joke
Old Aug 5, 2004 | 09:24 AM
Filthy Focker!'s Avatar
Default Re: (dantastic)
When i see that, i am tempted to say this.
1. Dilute your fuel
2. try leaning out the fuel mixture as much as possible
3. Try getting your engine to run hotter than usual by altering the coolant mixture
4. right before testing, take a really long drive.
The idea is you want to make the engine run as hot as possible with the least amount of fuel possible. Thus bring hydrocarbons down enough to pass the test.
fs
Old Aug 5, 2004 | 09:25 AM
Sijray21's Avatar
Default Re: (blue2ksi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2ksi &raquo;</TD></TR><TR><TD CLASS="quote">your cat takes care of your hydrocarbons, that what u failed correct? i dont know if it is possible to fix a cat but replace it or something and i think you'll be fine</TD></TR></TABLE>
i'd go ahead and replace the cat, that should take care of your problems
LAO
Jul 28, 2008 07:00 AM
dem0nk1d
Jul 7, 2006 11:11 AM
k7q
14
Mar 6, 2006 03:50 PM
Splangtastic
Jun 19, 2003 01:30 PM
MisterB
14
Sep 14, 2002 01:00 PM
