Motor mounts for my dual cammer ZC
Old Aug 4, 2004 | 09:54 AM
JapJunkie's Avatar
Default Motor mounts for my dual cammer ZC
Does any company make aftermarket motor mounts for my DOHC ZC in my 88 hatch? I need to replace mine Or what other options do i have, i want brand new motor mounts, do Hasport or Place make some? TIA
Old Aug 4, 2004 | 10:09 AM
spiceisler's Avatar
Default Re: Motor mounts for my dual cammer ZC (hondadict)
Stock Civic would work and if you don't mind the vibration get the poly inserts.
Old Aug 4, 2004 | 10:12 AM
CRX T-Si's Avatar
ES makes inserts.
But if your mounts have not cracked yet then you can fill them up with windo-weld.
Here is the link that will help you if you decide to fill the mount up. Remember this will only work if your mounts have not yet seperated yet. If so then just get new mounts, for the D motor I don't believe their that expensive. right??
http://www.raktron.com/misc/mt.htm
Old Aug 4, 2004 | 10:17 AM
JapJunkie's Avatar
Default Re: Motor mounts for my dual cammer ZC (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">ES makes inserts.
theyre not expensive, i just want aftermarket ones But OEM is my best option i guess.
VTECcnIT
Apr 17, 2006 07:54 PM
JapJunkie
Aug 27, 2004 04:49 PM
EGcivicBoy
12
Dec 25, 2003 12:40 PM
