Is it normal for the temp gage to slightly increase when cooling system has been changed?
Old Aug 4, 2004 | 09:27 AM
dman81's Avatar
Default Is it normal for the temp gage to slightly increase when cooling system has been changed?
Yesterday I had my radiator replaced with an aftermarket and had the thermostat replaced as well with a generic Autozone type. Today was my first drive with the new cooling system and I noticed the temp. gage slightly increased. Its still below the middle marker. Is this something I should worry about? Could it be the thermostat?
Daniel
Old Aug 4, 2004 | 10:20 AM
JimBlake's Avatar
Default Re: Is it normal for the temp gage to slightly increase when cooling system has been changed? (dman8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dman81 &raquo;</TD></TR><TR><TD CLASS="quote">... Its still below the middle marker. Is this something I should worry about?</TD></TR></TABLE>Probably OK, just keep an eye on it to make sure it doesn't climb. But that's true even if you used a genuine dealer t-stat.
Below the 50% mark is good, but how much higher is it, really?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dman81 &raquo;</TD></TR><TR><TD CLASS="quote">Could it be the thermostat?</TD></TR></TABLE>Sure. They're not the most accurate things...
Old Aug 4, 2004 | 10:36 AM
PnX-R's Avatar
I could've sworn that it's possible to install the T-stat backwards also..
Old Aug 4, 2004 | 10:48 AM
dman81's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks Jim for the reply. I've been driving my car for two years, I'm so use to seeing the marker at a specific point in the gage that I know its climbed. Its still a good ways below the middle marker. But as you said, as long as its below the middle marker I'm okay. I'll be observing the gage in the next few days.
THX
Daniel
boostedeg9
24
Oct 5, 2006 12:42 PM
parker14us2000
Oct 17, 2005 12:57 PM
JDM-EJ1
May 16, 2005 08:07 AM
130R
17
Dec 27, 2004 07:07 PM
fridexter
Nov 20, 2004 02:52 PM
