could my SAFC be the problem?
my car is not starting after driving for a while, it bogs really bad when driving in any gear, at any rpm, and the air/fuel gauge is either off, all the leds are lit up, or it is totally lean. The temp gauge will also jump up to overheating every now and then, but the car is not overheating.
Anyway, I recently installed a SAFCII in my car, but haven't tuned it yet, i haven't even touched it because this problem started happening.
Could this be the problem?
Since install, are you throwing any codes? I had a similar problem, bought a used safc and there was already adjustments set from the previous owner, which caused me to bog and run extremely rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional »</TD></TR><TR><TD CLASS="quote">Since install, are you throwing any codes? I had a similar problem, bought a used safc and there was already adjustments set from the previous owner, which caused me to bog and run extremely rich</TD></TR></TABLE>
Not throwing any codes. The SAFC is brand new, and unless there are set codes already on it, everything is untouched. But i am bogging and running either really rich or lean, not sure which because the a/f gauge doesn't function right.
