Dancing Tachometer Needle
Old Sep 30, 2006 | 03:33 PM
Haleiwa-Brando's Avatar
Default Dancing Tachometer Needle
Old Sep 30, 2006 | 03:57 PM
DeDonDeRosa's Avatar
Default Re: Dancing Tachometer Needle (Haleiwa-Brando)
IGNITOR!!!!!!!!!!!!!!!!!!!!! in the dist!!!!!!! 100% theres your problem
NUMBER 8!!!!
Old Sep 30, 2006 | 05:05 PM
BRICKHEAD's Avatar
Default Re: Dancing Tachometer Needle (DeDonDeRosa)
could also be a vaccume leak?
Old Sep 30, 2006 | 06:04 PM
itralex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">IGNITOR!!!!!!!!!!!!!!!!!!!!! in the dist!!!!!!! 100% theres your problem
NUMBER 8!!!!
WORD!
Get it replaced soon, or your car will die all of a sudden and you'll be screwed
I had the same thing happen to mine, it was a wasy 15min DIY
Old Sep 30, 2006 | 06:48 PM
bmw325is's Avatar
im having this problem with the temp gauge. it jumps all around, then just flops and dies on cold, then if i accelerate it'll jump up to halfway stay there then flop and die again. are bumps knocking loose a connection?
Old Sep 30, 2006 | 09:17 PM
KayOs's Avatar
It definitely has something to do with the distributor. Tach leads directly into your distributor. One of the components is or will fail soon.
Keep us updated on resolution as I have come across threads from 2 other HT members who experienced similar problems.
Old Sep 30, 2006 | 10:37 PM
RTW DC2R's Avatar
my civic has been doing that for quite some time now, usually only on startup though. hasnt died completely yet though.
Old Oct 1, 2006 | 02:45 AM
Duane_in_Japan's Avatar
Default Re: (RTW DC2R)
I will throw in an 80% ignitor and a 20% on the coil, professionally I would say change them both but your pocket book may say otherwise.
A bad ignitor or a bad coil can drag the new single part down that you just replace, its been that way for years.
joes92civic
Mar 24, 2007 07:46 AM
michjdm
Feb 27, 2007 01:44 PM
Slammin585
May 24, 2006 09:54 PM
WhiteGSR95
Feb 1, 2005 07:43 PM
RGoose18
May 20, 2004 04:47 PM
